I'm trying to extract linear velocity from an object's tf frame using lookupTwist.
I simulate an object moving around on a 400m track. I used simple line and circle equations to describe its position at time t at fixed velocity.
Looking at the tf in rviz, it performs correctly and moves in a smooth oval.
Now when I try and extract velocity using lookupTwist, the linear velocities are all messed up. In straight lines the linear velocities are correct, but in the turns the velocities values sky rocket. For example if I set my simulated object to move at 10 m/s, on a turn the velocity would instantly shoot up to 50m/s go back down halfway way through the turn, shoot back up to 50 just before the straight away.
This is because the code I'm using to extract the velocity from a tf. Is there something I should be aware of or is my environment bugged?
geometry_msgs::Twist objectTwist;
tf::TransformListener listener;
listener.lookupTwist("/map", "/sim_object", ros::Time(0), ros::Duration(0.1), objectTwist);
cout << sqrt(objectTwist.linear.x * objectTwist.linear.x + objectTwist.linear.y * objectTwist.linear.y) << endl;
Originally posted by uwleahcim on ROS Answers with karma: 101 on 2016-06-29
I think I might have fixed my issue
Anyways, after playing around with the parameters, I think I finally have the correct velocity values.
listener.lookupTwist("/sim_object", "/map", "sim_object", tf::Point(), "map", ros::Time(0), ros::Duration(0.1), objectTwist);
I really don't have an idea what "tf::Point()" is suppose to do. I would love if someone can explain to me exactly what the above code is doing.
Originally posted by uwleahcim with karma: 101 on 2016-06-29
Comment by jarvisschultz on 2016-06-30:
Be a little careful when using this function. I believe there is a bug that in some cases may result in incorrect values. I spent some time looking into it, but never got to the bottom of it: https://github.com/ros/geometry/issues/43
