Say I have this solar panel that outputs 6V at 330mA, or ~1.98 Watts. If I connect that to Arduino, which expects a 5V supply at (roughly) 50mA, then the Arduino as a whole requires 5V * .05A = 0.25 Watts to power it. To me, if I understand this correctly, then in perfect weather/sunlight, the solar panel will power Arduino all day long, no problem.
Now let's say we wire up 4 motors to the Arduino, each of which draw 250 Watts. Now the Arduino + 4 motors are drawing ~1.25 Watts. But since the panels are still outputting 1.98 Watts, I would think that (again, under perfect sunlight) the panel would power the Arduino and motors all day long, no problem.
Now we add 4 more motors to the Arduino circuit, for a total of 8 motors. The circuit is now drawing 1.25 Watts + 1 W = 2.25 Watts. I would expect the solar panel to no longer be capable of powering the circuit, at least properly.
My first concern here is: am I understanding these 3 scenarios correctly? If not, where is my understanding going awry?
Assuming I'm more or less on track, my next question is: can solar panels be "daisy chained" together to increase total power output? In the third case above, is there a way to add a second solar panel into the mix, effectively making the two panels output 1.98 Watts * 2 = 3.96 Watts, which would then make them capable of powering the Arduino and its 8 motors (yet again, assuming perfect weather/sunlight conditions)?
