Hi to all,
I have a *.bag file which contains different topics and I would like to extract only a specific topic and record it in a new bag file.
Is it possible?
I've read about a solution which enable users to extract a topic and save its content in a CSV file, but the problem is that I need to have another *.bag file and not CSV.
Is there any solution?
Thank you!!
Originally posted by Marcus Barnet on ROS Answers with karma: 287 on 2016-06-28
This is the first example listed for the rosbag filter command: http://wiki.ros.org/rosbag/Commandline#filter
rosbag filter my.bag only-tf.bag "topic == '/tf'"
If you want to extract a topic other than /tf, simply change that portion of the command.
Note that the expression topic == '/tf' is surrounded in double quotes so that it isn't interpreted by the shell, and /tf is further enclosed in single quotes because it is a python string literal.
Originally posted by ahendrix with karma: 47576 on 2016-06-28
Post score: 4
Comment by Marcus Barnet on 2016-06-28:
Thank you!!!
Comment by petitchamp on 2019-02-04:
Is there any way to extract more than one topic from a bag file? something like "topic == '/tf1,/tf2'"?
Comment by ahendrix on 2019-02-04:
Yes; you can use any python expression as the filte, so you could do "topic in ['/topic1', '/topic2']" or even use python's string or regex matching!
