There are plenty of articles online about the Jetson GPIO but there's not much about using it with ROS.
Is there a simple way to integrate Jetson GPIO with ROS or do you have to control everything manually through your ROS cpp program?
Originally posted by jacksonkr_ on ROS Answers with karma: 396 on 2016-06-26
You can do it both ways. You can directly access the pins from your program with C++. The other approach is to write a node that uses topics or services to access or set the pins. For reference you can look at these resources from the wiki:
Writing a Simple Service and Client (C++)
Writing a Simple Publisher and Subscriber (C++)
I don't know how you are managing permissions on your robot, but for me to access GPIO on my Beaglebone, I just made sudo passwordless and then when my node launched, I chmodded the /dev/class/gpio folder to allow my user to access it. Hope this helps! luketheduke
Originally posted by luketheduke with karma: 285 on 2016-06-26
Comment by jacksonkr_ on 2016-06-26:
Great info! I'm glad you brought up permissions. I think I'll take your passwordless sudo approach. I have wifi / ssh on this machine but sudo won't apply unless someone is logged in so I should be good.
Comment by luketheduke on 2016-06-26:
Also, another thing to note is that if you are using the robot_upstart package to launch your nodes on boot, then you want to modify the source code for it to use sudo -u USERNAME instead of the setuid that it uses itself. In the unmodified state, robot_upstart doesn't play nice with GPIO.
If this answer answers your question, please mark it solved by pressing the button below the upvote/downvote buttons. This helps improve the ROS community. Thanks, luketheduke
Comment by CoachAllen on 2020-01-15:
Is there an include statement for GPIO in C++? Like #include /jetson/gpio
Comment by luketheduke on 2020-01-15:
There are several different approaches to controlling GPIO with the Jetson. Because C++ is such a low level language here is the recommended approach from the Nvidia forums: https://devtalk.nvidia.com/default/topic/1052379/jetson-nano/how-to-use-gpio-in-c-language/post/5342398/#5342398 You can also try this library: https://github.com/brgl/libgpiod
Comment by CoachAllen on 2020-01-26:
So you would merely make the gpio availble to any package calling it?
Comment by luketheduke on 2020-04-20:
It depends on what approach you want to take, you could either integrate GPIO into every package that needed it or make one package that handles all GPIO and communicates over a topic/service.
