Hi there,
My ros distribution is indigo and my ubuntu distribution is 14.04.
I'm currently learning ros control. And it speed learning curve really makes me frustrated.
Here is my question, I tried the Gazebo ros control tutorial at http://gazebosim.org/tutorials/?tut=ros_control.
When typing "roslaunch rrbot_control rrbot_control.launch" it worked at the first time. But things get weird when I come back several days later( Accurately yesterday..... ). I got errors when loading the control_plugin.
[ERROR] [1466858294.522754886, 17.133000000]: Could not load class effort_controllers/JointPositionController: MultiLibraryClassLoader: Could not create object of class type effort_controllers::JointPositionController as no factory exists for it. Make sure that the library exists and was explicitly loaded through MultiLibraryClassLoader::loadLibrary() [ERROR] [1466858294.522799828, 17.133000000]: Could not load controller 'joint1_position_controller' because controller type 'effort_controllers/JointPositionController' does not exist. [ERROR] [1466858294.522831954, 17.133000000]: Use 'rosservice call controller_manager/list_controller_types' to get the available types
But when I call the service as the third error suggested I find the effort_controllers/JointPositionController exist. And when I type "rospack find effort_controllers" I can find the package under ros/indigo/share/ Furthermore at file effort_controller_plugins.xml it actually contain:
name="effort_controllers/JointPositionController" type="effort_controllers::JointPositionController" base_class_type="controller_interface::ControllerBase"> The JointPositionController tracks position commands. It expects a EffortJointInterface type of hardware interface.
I try to remove and re-install the effort_controllers use "apt-get" several times but the errors still exist.
Please help me out of this.
Thanks in advance. Erli
Originally posted by cangjiaxuan on ROS Answers with karma: 20 on 2016-06-25
