I've used ros control multiple times for commanding joint positions in gazebo mainly following the rrbot example, but never in a real robot or a stripped down non-gazebo simulation. How is it done, and is there an example?
As I understand it libgazebo_ros_control is loaded as a plugin into gazebo, then the controller_manager spawner asks it to create a controller for each joint specified. Is there a generic non-gazebo service provider of controller_manager/load_controller that subscribes to joint feedback (derived from encoders) and desired joint position/velocity/effort and publishes joint commands according to the controller type and gain parameters?
Originally posted by lucasw on ROS Answers with karma: 8729 on 2016-06-23
This is only a partial answer, but have a look at Dave Coleman's ros_control_boilerplate.
The gazebo_ros_control package is essentially just one implementation of a ros_control hardware_interface subclass/plugin, which together with a node running the read()/write() loop (which may be run from a hard real-time task, or from a regular pthread, or something else) forms the bulk of a ros_control setup.
For a real piece of hardware, the process to setup ros_control is exactly the same, apart from the fact that you'll have to provide a hardware_interface implementation for your platform. After that, (almost) everything else is the same.
I highly recommend to view the presentation Adolfo gave at ROSCon14 if you haven't already.
Originally posted by gvdhoorn with karma: 86574 on 2016-06-24
