I record my bag file using this command:
rosbag record /camera/rgb/image_raw -O kinectrgb
And
rosbag info kinectrgb.bag
For its content I get this:
path:        kinectrgb.bag
version:     2.0
duration:    6.2s
start:       Jun 20 2016 16:19:52.89 (1466432392.89)
end:         Jun 20 2016 16:19:59.09 (1466432399.09)
compression: none [185/185 chunks]
types:       sensor_msgs/Image [060021388200f6f0f447d0fcd9c64743]
topics:      /camera/rgb/image_raw   185 msgs    : sensor_msgs/Image
But when I try to extract the images I don't get anything..
roslaunch export.launch
It says process has finished cleanly but I don't get the images in ROS_HOME ~/.ros
... logging to /home/jros/.ros/log/ff16c6e0-36f1-11e6-b3d4-5c260a35b6aa/roslaunch-jros-1932.log
Press Ctrl-C to interrupt
started roslaunch server http://jros:36064/
SUMMARY
PARAMETERS
 * /rosdistro: indigo
 * /rosversion: 1.11.19
NODES
    extract (image_view/extract_images)
    rosbag (rosbag/play)
core service [/rosout] found
process[rosbag-1]: started with pid [1950]
process[extract-2]: started with pid [1951]
[ INFO] [1466432724.837729370]: Initialized sec per frame to 0.100000
[rosbag-1] process has finished cleanly
log file: /home/jros/.ros/log/ff16c6e0-36f1-11e6-b3d4-5c260a35b6aa/rosbag-1*.log
My launch file:
<launch>
  <node pkg="rosbag" type="play" name="rosbag" args="-d 2 $(find imagesequencekinect)/kinectrgb.bag"/>
  <node name="extract" pkg="image_view" type="extract_images" respawn="false" output="screen" cwd="ROS_HOME">
    <remap from="image" to="/camera/image_raw"/>
  </node>
</launch>
What am I doing wrong?
What does -d 2 mean in the launch file arg?
Originally posted by ROSkinect on ROS Answers with karma: 751 on 2016-06-20
Looks like you use the wrong topic name for extract_images in the launchfile
vs
-d means "delay after advertising the topics before sending the first message" or as rosbag play --help puts it:
-d SEC, --delay=SEC   sleep SEC seconds after every advertise call (to allow subscribers to connect)
Originally posted by Felix Endres with karma: 6468 on 2016-06-20
