Hi i am using a 2d lidar tilted at an angle such that it hits the ground and we are also using a mono-cam for detection of objects (static etc) . Is there any way that i can fuse these two reading i.e the lidar readings onto the camera readings so that i can measure the dist of object through this fuse data(width and x,y positions of the boundaries)
Originally posted by rajnunes on ROS Answers with karma: 73 on 2016-06-17
your answer is here.
Originally posted by dinesh with karma: 932 on 2016-06-19
