I use command catkin_make_isolated in the terminal, error is shown below:
    CMake Error at cmake_install.cmake:111 (FILE):
      file INSTALL cannot set permissions on
      "/home/gupta/catkin_ws_2/install_isolated/lib/libuwsim.so"
make: *** [install] Error 1
<== Failed to process package 'uwsim':
  Command '/home/gupta/catkin_ws_2/install_isolated/env.sh make install' returned non-zero exit status 2
Reproduce this error by running:
==> cd /home/gupta/catkin_ws_2/build_isolated/uwsim && /home/gupta/catkin_ws_2/install_isolated/env.sh make install
Command failed, exiting.
Originally posted by ZYS on ROS Answers with karma: 108 on 2016-06-15
Does the user your using have a write access at /home/gupta/catkin_ws_2/ and subsequent folders?
Originally posted by 130s with karma: 10937 on 2016-06-15
Comment by rayane on 2021-03-09:
PLZ, tell me how to give the user access to the folder!!! Thanks
Comment by 130s on 2021-03-12:
@rayane Please ask somewhere else because 1) That's not related to ROS at all 2) There can be a number of different ways to do so depending on your particular situation.
