The dynamic reconfigure code generation looks it is being executed unconditionally even if the python generation script (.cfg) did not change.
This means that everytime that catkin_make command is called some new header (.h) files are generated by the dynamic_reconfigure cmake functionality. Because of this, the "incremental build mechanism" of cmake gets broken and your *.cpp files that depens on those headers recompile. This may make the development process slower.
Is this the expected behavior of the dynamic_reconfigure code generation system? Is there any way to avoid breaking the incremental build of cmake?
Until the current moment I have worked with these approaches (but I would like to avoid them because they do not satisfy me totally):
  • the dynamic reconfigure files to other project and use the catkin_make's "black package list"
  • building manually the targets I need the catkin_make's "--pkg" flag
Originally posted by Pablo Iñigo Blasco on ROS Answers with karma: 2982 on 2016-06-15
dynamic_reconfigure should not regenerate the headers unless the .cfg file actually changes.
Basic reasons for generating headers each time can be:
  • file name doesn't match the class name, so cmake doesn't detect that the headers have been generated
  • using the rosbuild generator with catkin
Have a look at http://answers.ros.org/question/165426/generate_dynamic_reconfigure_options-executed-every-build/ for another discussion of this topic.
Originally posted by ahendrix with karma: 47576 on 2016-06-15
Comment by Pablo Iñigo Blasco on 2016-06-15:
Really worked. Thanks. This small detail can really decrease the development productivity.
