hi, currently i can create maps with gmapping + laser_scan_matcher and hector_slam.
i want to see obstacles in the map i create. so costmap is the answer i guess.
i just have lms100 laser scanner, not a robot system to control so in navigation stack, base_controler requirement is not met. so can i use a part of navigation stack which includes costmap_2d especially? if so, what is the proper way to do it?
Originally posted by bsk on ROS Answers with karma: 73 on 2016-06-14
