Hello
i try to xtion, kobuki(2 wheel mobile robot).
i read http://wiki.ros.org/rtabmap_ros/Tutorials/SetupOnYourRobot.
and apply my launch.
i modify rgbd_mapping.launch.and program work normally.
<arg name="subscribe_scan" default="true"/> <!-- Assuming 2D scan if set, rtabmap will do 3DoF mapping instead of 6DoF -->
<arg name="scan_topic" default="/kinect_scan"/>
<arg name="subscribe_scan_cloud" default="false"/> <!-- Assuming 3D scan if set -->
<arg name="scan_cloud_topic" default="/scan_cloud"/>
<arg name="visual_odometry" default="false"/> <!-- Generate visual odometry -->
<arg name="odom_topic" default="/odom"/> <!-- Odometry topic used if visual_odometry is false -->
<!-- Kinect cloud to laser scan 11cm 16cm-->
<node pkg="depthimage_to_laserscan" type="depthimage_to_laserscan" name="depthimage_to_laserscan">
<remap from="image" to="/camera/depth_registered/image_raw"/>
<remap from="camera_info" to="/camera/depth_registered/camera_info"/>
<remap from="scan" to="/kinect_scan"/>
<param name="range_max" type="double" value="4"/>
</node>
<node pkg="tf" type="static_transform_publisher" name="odom_camera_tf" args="0.11 0 0.16 0 0 0 1 /base_footprint /camera_link 100" />
but result is strange.
first. set my xtion from robot ( 0.11cm, 0, 0.16cm) so i add tf broadcaster.
result is below link.
https://plus.google.com/110617758145783258429/posts/RCTNymgamWp
1.point cloud and map cloud is different.
is the result normal??
2.map is bad when robot turn a round and go to origin.
https://plus.google.com/110617758145783258429/posts/KcxDVQqxNyg
full launch file.
<launch>
<!-- Your RGB-D sensor should be already started with "depth_registration:=true".
Examples:
$ roslaunch freenect_launch freenect.launch depth_registration:=true
$ roslaunch openni2_launch openni2.launch depth_registration:=true -->
<!-- Choose visualization -->
<arg name="rviz" default="false" />
<arg name="rtabmapviz" default="true" />
<!-- Localization-only mode -->
<arg name="localization" default="false"/>
<!-- Corresponding config files -->
<arg name="rtabmapviz_cfg" default="-d $(find rtabmap_ros)/launch/config/rgbd_gui.ini" />
<arg name="rviz_cfg" default="-d $(find rtabmap_ros)/launch/config/rgbd.rviz" />
<arg name="frame_id" default="camera_link"/> <!-- Fixed frame id, you may set "base_link" or "base_footprint" if they are published -->
<arg name="time_threshold" default="0"/> <!-- (ms) If not 0 ms, memory management is used to keep processing time on this fixed limit. -->
<arg name="optimize_from_last_node" default="false"/> <!-- Optimize the map from the last node. Should be true on multi-session mapping and when time threshold is set -->
<arg name="database_path" default="~/.ros/rtabmap.db"/>
<arg name="rtabmap_args" default=""/> <!-- delete_db_on_start, udebug -->
<arg name="launch_prefix" default=""/> <!-- for debugging purpose, it fills launch-prefix tag of the nodes -->
<arg name="rgb_topic" default="/camera/rgb/image_rect_color" />
<arg name="depth_registered_topic" default="/camera/depth_registered/image_raw" />
<arg name="camera_info_topic" default="/camera/rgb/camera_info" />
<arg name="compressed" default="false"/>
<arg name="convert_depth_to_mm" default="true"/>
**<arg name="subscribe_scan" default="true"/> <!-- Assuming 2D scan if set, rtabmap will do 3DoF mapping instead of 6DoF -->
<arg name="scan_topic" default="/kinect_scan"/>**
<arg name="namespace" default="rtabmap"/>
<arg name="wait_for_transform" default="0.2"/>
</node>
<!-- Nodes -->
<group ns="$(arg namespace)">
<node if="$(arg compressed)" name="republish_rgb" type="republish" pkg="image_transport" args="compressed in:=$(arg rgb_topic) raw out:=$(arg rgb_topic)" />
<node if="$(arg compressed)" name="republish_depth" type="republish" pkg="image_transport" args="compressedDepth in:=$(arg depth_registered_topic) raw out:=$(arg depth_registered_topic)" />
<!-- Odometry -->
<node if="$(arg visual_odometry)" pkg="rtabmap_ros" type="rgbd_odometry" name="rgbd_odometry" output="screen" args="$(arg rtabmap_args)" launch-prefix="$(arg launch_prefix)">
<remap from="rgb/image" to="$(arg rgb_topic)"/>
<remap from="depth/image" to="$(arg depth_registered_topic)"/>
<remap from="rgb/camera_info" to="$(arg camera_info_topic)"/>
<param name="frame_id" type="string" value="$(arg frame_id)"/>
<param name="wait_for_transform_duration" type="double" value="$(arg wait_for_transform)"/>
<param name="Odom/FillInfoData" type="string" value="true"/>
</node>
<!-- Visual SLAM (robot side) -->
<node name="rtabmap" pkg="rtabmap_ros" type="rtabmap" output="screen" args="$(arg rtabmap_args)" launch-prefix="$(arg launch_prefix)">
<param name="subscribe_depth" type="bool" value="true"/>
<param name="subscribe_scan" type="bool" value="$(arg subscribe_scan)"/>
<param name="subscribe_scan_cloud" type="bool" value="$(arg subscribe_scan_cloud)"/>
<param name="database_path" type="string" value="$(arg database_path)"/>
<remap from="scan" to="$(arg scan_topic)"/>
<remap from="scan_cloud" to="$(arg scan_cloud_topic)"/>
<remap unless="$(arg visual_odometry)" from="odom" to="$(arg odom_topic)"/>
<param name="Rtabmap/TimeThr" type="string" value="$(arg time_threshold)"/>
<param name="RGBD/OptimizeFromGraphEnd" type="string" value="$(arg optimize_from_last_node)"/>
<param name="Mem/SaveDepth16Format" type="string" value="$(arg convert_depth_to_mm)"/>
<!-- localization mode -->
<param if="$(arg localization)" name="Mem/IncrementalMemory" type="string" value="false"/>
<param unless="$(arg localization)" name="Mem/IncrementalMemory" type="string" value="true"/>
<param name="Mem/InitWMWithAllNodes" type="string" value="$(arg localization)"/>
<!-- when 2D scan is set -->
<param if="$(arg subscribe_scan)" name="Optimizer/Slam2D" type="string" value="true"/>
<param if="$(arg subscribe_scan)" name="Icp/CorrespondenceRatio" type="string" value="0.25"/>
<param if="$(arg subscribe_scan)" name="Reg/Strategy" type="string" value="1"/>
<param if="$(arg subscribe_scan)" name="Reg/Force3DoF" type="string" value="true"/>
<!-- when 3D scan is set -->
<param if="$(arg subscribe_scan_cloud)" name="Reg/Strategy" type="string" value="1"/>
</node>
<!-- Visualisation RTAB-Map -->
<node if="$(arg rtabmapviz)" pkg="rtabmap_ros" type="rtabmapviz" name="rtabmapviz" args="$(arg rtabmapviz_cfg)" output="screen" launch-prefix="$(arg launch_prefix)">
<param name="subscribe_odom_info" type="bool" value="$(arg visual_odometry)"/>
</node>
</group>
<!-- Visualization RVIZ -->
<node if="$(arg rviz)" pkg="rviz" type="rviz" name="rviz" args="$(arg rviz_cfg)"/>
<!-- sync cloud with odometry and voxelize the point cloud (for fast visualization in rviz) -->
<node if="$(arg rviz)" pkg="nodelet" type="nodelet" name="standalone_nodelet" args="manager" output="screen"/>
<node if="$(arg rviz)" pkg="nodelet" type="nodelet" name="data_odom_sync" args="load rtabmap_ros/data_odom_sync standalone_nodelet">
<remap from="rgb/image_in" to="$(arg rgb_topic)"/>
<remap from="depth/image_in" to="$(arg depth_registered_topic)"/>
<remap from="rgb/camera_info_in" to="$(arg camera_info_topic)"/>
<remap if="$(arg visual_odometry)" from="odom_in" to="rtabmap/odom"/>
<remap unless="$(arg visual_odometry)" from="odom_in" to="$(arg odom_topic)"/>
<remap from="rgb/image_out" to="data_odom_sync/image"/>
<remap from="depth/image_out" to="data_odom_sync/depth"/>
<remap from="rgb/camera_info_out" to="data_odom_sync/camera_info"/>
<remap from="odom_out" to="odom_sync"/>
</node>
<node if="$(arg rviz)" pkg="nodelet" type="nodelet" name="points_xyzrgb" args="load rtabmap_ros/point_cloud_xyzrgb standalone_nodelet">
<remap from="rgb/image" to="data_odom_sync/image"/>
<remap from="depth/image" to="data_odom_sync/depth"/>
<remap from="rgb/camera_info" to="data_odom_sync/camera_info"/>
<remap from="cloud" to="voxel_cloud" />
<param name="decimation" type="double" value="2"/>
<param name="voxel_size" type="double" value="0.02"/>
</node>
</launch>
Originally posted by JunJun on ROS Answers with karma: 26 on 2016-06-07
