I know that is a question that has been asked too many times, but still its not clear to me. I read online that it isn't but some people say that they control their robots under ROS in applications with hard real time constraints. So, because I need some technical arguments (rather than a plain "ros is not real time") I will be more specific (suppose we have ROS under a RTOS):
- I read that ROS uses a TCP/IP-based communication for ROS topics and I know that TCP/IP is not reliable. That means I cannot use topics in a real time loop? For instance send a control signal to my system publishing it to a topic, and the system sending me some feedback via a topic?
- If I have a RTOS (eg Linux+Xenomai) can I build a real time control loop for a robot using ROS, or ROS will be a bottleneck?
Maybe the above are naive or I lack some knowledge, so please enlighten me!
Note: I define as a hard real time system (eg in 1KHz), the system that can guarantee that we will not miss a thing (if the control loop fails to run every 1ms the system fails).
