Hi,
We are trying to visualize in realtime the VLP-16 data in RVIZ.
Our config :
  • Ubuntu 14.04
  • ROS indigo
  • Velodyne VLP-16
We launch in several terminals these following commands :
TTY0 :
$ sudo route add 192.168.1.201 eth0
$ roscore
TTY1 :
$ roslaunch velodyne_pointcloud VLP16-points.launch
TTY2 :
$ rosrun velodyne_pointcloud cloud_node _calibration:=($mypath)/VLP16db.yaml
TTY3 :
$ rosrun rviz rviz -f velodyne
We can see it real time for like a few minutes, and then it freezes.
When we look at the route -n command the velodyne route (192.168.1.201) is gone.
After this, if we enter the : sudo route add 192.168.1.201 eth0 command again, rviz shows data correctly in realtime.
Any ideas why the route disappears ?
Thank you in advance for any help you can provide.
Originally posted by ArthurAlear on ROS Answers with karma: 15 on 2016-06-03
Comment by gvdhoorn on 2016-06-03:
Is your machine a DHCP client? Could be that it's flushing the routes upon renewal of the lease. Check syslog or dmesg to see whether the 'loss of route' coincides with lease renewal.
Also: have you checked to see whether the route disappears when you're not running anything from ROS?
Comment by kmhallen on 2016-06-03:
Why are you running two instances of the cloud_node? VLP16-points.launch runs everything (including the cloud_node as a nodelet).
https://github.com/ros-drivers/velodyne/blob/master/velodyne_pointcloud/launch/VLP16_points.launch
  1. @kmhallen is right: don't run the cloud node, because VLP16-points.launch already starts the cloud nodelet. Since they are both publishing the same information to the /velodyne_points topic, the result will be confusing and waste cycles and bandwidth.
  2. The recommended method is to attach the Velodyne to its own ethernet port with a statically assigned IP in the 192.168.1.x range. We normally do it via the Ubuntu network manager like this:
  • IP address: 192.168.1.77
  • netmask: 255.255.255.0
  • gateway: 192.168.1.0
Setting up a VLP-16 is very similar to this 32E tutorial. We'd like to make a VLP-16 version of that tutorial some time soon.
Originally posted by joq with karma: 25443 on 2016-06-03
Comment by ArthurAlear on 2016-06-20:
Thanks for your answer !
