Hi!
I (only) have laser scanner LMS100 and i can create maps from hector_slam without odometry data...but i need to see obstacles / objects in the map.
So i think i should use a costmap like hector_costmap (or costmap_2d which is in another package)...but i don't now if it is usable with just laser data (without odometry data).
update: i tried and managed gmapping with laser scan matcher, so i now i think i can use costmap_2d in navigation stack with help of those...
by the way still dont know, can i use hector_costmap without odometry data?
Başak
Originally posted by bsk on ROS Answers with karma: 73 on 2016-06-03
Comment by jjbecomespheh on 2020-07-16:
Hi Basak, may I ask if you managed to hector_costmap for detecting obstacles using just laser data?
Hi,
you could try using this package to estimate odometry data from laserscans. http://wiki.ros.org/laser_scan_matcher
Originally posted by fsteinhardt with karma: 306 on 2016-06-04
