I was following pcl/tutorial steps, but after i downloaded the source code example_voxelgrid.cpp and named it as example.cpp and than calling catkin_make from the root directory, it is showing: CMake Error at /opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:83 (find_package): Could not find a package configuration file provided by "pcl_conversions" with any of the following names: pcl_conversionsConfig.cmake pcl_conversions-config.cmake , even if i followed the full steps of step 4.1 im still getting error at cmake_error. at starting of pcl/ros tutorial only im getting the errors, o man. im using ubuntu 14.04 with ros indigo, it has also said that for different version of ros the modification is deiiferent, i dont get that properly.
Originally posted by dinesh on ROS Answers with karma: 932 on 2016-06-01
reinstall the package and the dependencies, try again the tutorial steps. u'll get the result.
Originally posted by dinesh with karma: 932 on 2016-06-03
