Is ros-kinetic-desktop-full available? I have followed the steps from http://wiki.ros.org/kinetic/Installation/Ubuntu but keep getting the error E: Unable to locate package ors-kinetic-desktop-full when I enter sudo apt-get install ros-kinetic-desktop-full
Also if I try to click on the link given on the installation page where it says "or click here" the link fails.
Originally posted by dolphin123 on ROS Answers with karma: 21 on 2016-05-27
Comment by gvdhoorn on 2016-05-27:
It should be available, yes. See status_page/ros_kinetic_default.html?q=desktop. That is for x86/64 though, and you don't tell us your architecture / platform.
Comment by spmaniato on 2016-05-27:
@dolphin123, did Step 1.2 succeed? Did you do sudo apt-get update as instructed in Step 1.4? Also, keep in mind that "ROS Kinetic ONLY supports Wily (Ubuntu 15.10), Xenial (Ubuntu 16.04) and Jessie (Debian 8) for debian packages."
Comment by dolphin123 on 2016-05-27:
I am using a 64-bit PC with Ubuntu 16.04. Step 1.2 succeeded and I updated, but I still get the error above that the kinetic desktop full package cannot be located.
Does apt-cache search ros-kinetic find anything at all?
Comment by rospiguy on 2016-09-27:
In my case apt-cache search ros-kinetic produced a long list which included ros-kinetic-desktop but not ros-kinetic-desktop-full which apparently is not included in the download from http://packages.ros.org/ros/ubuntu. Installing per the second option in step 1.4 worked fine.
Comment by yuxwind on 2018-05-24:
As my platform is Ubuntu Trusty(14.04), only Indigo Igloo and Jade Turtle work for me. When I tried to install ros-kinetic-desktop-full, it reported the error as yours.
The complete list of target platform and ros version is at http://www.ros.org/reps/rep-0003.html#jade-turtle-may-2015-may-2017.
Comment by babayaga on 2019-03-13:
I tried installing ROS and got the same error running Ubuntu 16.04.6 LTS. I tried everything mentioned here , but it ain't working
"E: Unable to locate package ors-kinetic-desktop-full", didn't you just mistype 'ros'?
Originally posted by JamesWell with karma: 136 on 2016-06-03
Comment by kc2 on 2016-08-10:
Hi,my source list is fine but still got error on a pi 3: When "sudo apt-get update", it hit packages.ros.org jessie InRelease, and jessie/main armhf Packages, etc. But "apt-cache search ros-kinetic" gave error; or even "ros" returned nothing. I could install from src, but wonder if I did wrong. thks
I had a similar issue, the problem for me was that I did not run apt-get update after setting up the ros sources.list and keys.
running sudo apt-get update after setting up the sources and keys downloaded the following packages:
Get:8 http://packages.ros.org/ros/ubuntu xenial InRelease [4,025 B]
Get:9 http://packages.ros.org/ros/ubuntu xenial/main armhf Packages [245 kB]
Running the following install command after that worked fine:
Post score: 5
Comment by Haifei on 2017-12-31:
Thanks a lot! this works, following steps in http://wiki.ros.org/kinetic/Installation/Ubuntu.
