Hello !
I try to get the situation of my robot using the following code:
tf::TransformListener listener;
tf::StampedTransform transform;
listener.lookupTransform("/move_base/local_costmap/global_frame", "/move_base/local_costmap/robot_base_frame", ros::Time::now(), transform);
and use it using the following methods:
transform.getOrigin().x()
transform.getOrigin().y()
My problem is when I run this code, I get the the following error:
[ERROR] [..., ...]: "move_base/local_costmap/global_frame" passed to lookupTransform argument target_frame does not exist.
But when I check the "move_base/local_costmap/global_frame" parameter existence (the same with the "move_base/local_costmap/robot_base_frame" parameter), I find that it exists well and is settled to 'odom' value (respectively 'base_link').
I also tried to write directly "odom" and "base_link" instead of "move_base/local_costmap/global_frame" and "move_base/local_costmap/robot_base_frame" but I have the same error:
[ERROR] [..., ...]: "odom" passed to lookupTransform argument target_frame does not exist.
However, when I do:
rosrun tf view_frames
I have the following tree: image description
The first and the third frames are those which interest me.
Moreover, when I use the command:
rosrun tf tf_monitor odom base_link
I have this:
RESULTS: for odom to base_link
Chain is: odom -> base_footprint -> base_link
Net delay     avg = 0.00599856: max = 0.016
Frames:
Frame: base_footprint published by unknown_publisher Average Delay: 0.000963 Max Delay: 0.005
Frame: base_link published by unknown_publisher Average Delay: -0.500052 Max Delay: 0
All Broadcasters:
Node: unknown_publisher 146.156 Hz, Average Delay: -0.102412 Max Delay: 0.005
If someone can help me, I will be very grateful,
lfr
Originally posted by lfr on ROS Answers with karma: 201 on 2016-05-26
Comment by NEngelhard on 2016-05-27:
Check my update with waitforTransform
You have to pass the frame name directly to lookupTransform and not the name of a parameter that contains the frame name. You can't expect such a function to decide if you passed the name of a frame or of a parameter.
Next, you should add a listener.waitForTransform before you try to look up. You just created the listener so it had no time to collect any transformations on the /tf-topic.
BTW: You should have a look at TF2. It reduces the used bandwidth and gets rid of the republishing of static transformations.
Originally posted by NEngelhard with karma: 3519 on 2016-05-26
Comment by lfr on 2016-05-27:
Thank you for answering me.
I already tried to use 'odom' instead of "move_base/local_costmap/global_frame" and 'base_link' instead of "move_base/local_costmap/robot_base_frame" but it generates the same error with 'odom'.
What is published on /tf and /tf_static?
On /tf, a lot of things are published non-stop but nothing is published on /tf_static.
This is a sample of data published on /tf:
transforms:
  • header: seq: 0 stamp: secs: 77 nsecs: 129000000 frame_id: odom child_frame_id: base_footprint
transform:
  translation:
    x: 0.000368870873302
    y: 0.000194895575539
    z: 0.0839691068639
  rotation:
    x: -3.22346543618e-07
    y: 4.25625394189e-07
    z: 0.000436463216874
    w: 0.99999990475
Thank you, it works successfully !!
Really thank you.
