Hello, we've faced a really strange problem. We're moving message/service definitions into standalone packages, and we've faced this:
virtual_camera_msgs/CMakeLists.txt:
make_minimum_required(VERSION 2.8.3)
project(virtual_camera_msgs)
find_package(catkin REQUIRED COMPONENTS message_generation std_msgs)
add_message_files(FILES AddRealCamera.msg VirtualCameraParameters.msg)
generate_messages(DEPENDENCIES std_msgs)
catkin_package(CATKIN_DEPENDS message_runtime std_msgs)
virtual_camera/CMakeLists.txt:
project(virtual_camera)
set(THIS_PROJECT_DEPS
  virtual_camera_msgs
  ${THIS_PROJECT_DEPS}
catkin_package(CATKIN_DEPENDS ${THIS_PROJECT_DEPS})
include_directories(include ${catkin_INCLUDE_DIRS})
add_executable(keyboard_teleop src/keyboard_teleop.cpp)
target_link_libraries(keyboard_teleop ${catkin_LIBRARIES})
I was almost sure it is not needed to add add_dependencies(keyboard_teleop virtual_camera_msgs_generate_messages_cpp), since CATKIN_DEPENDS on the whole virtual_camera_msgs package should automatically build all of its targets before continuing to the package that includes it.
However, if I don't add the add_dependencies clause, the build fails not finding virtual_camera_msgs/AddRealCamera.h, which should be built by the message package.
Do you know why the generate_messages_cpp target is not run before building the dependent package?
Using catkin_make --use-ninja, I've tried removing build and devel and sourcing the setup.bashs again.
Originally posted by peci1 on ROS Answers with karma: 1366 on 2016-05-23
Comment by peci1 on 2016-05-25:
Created an issue: https://github.com/ros/catkin/issues/801
Got an answer in the issue. It is said to be a technical limitation of catkin. You should indeed add add_dependencies(target catkin_EXPORTED_TARGETS) to every target that uses (any) ROS messages or other autogenerated code.
Originally posted by peci1 with karma: 1366 on 2016-05-26
Comment by gvdhoorn on 2016-05-26:\
I think this is actually a CMake limitation, not necessarily catkin.
