I'm looking for some cheap hardware that would offer me results decent enough to continue my experimentation.
I've been looking into how to obtain hardware for learning about stereo vision and 3D reconstruction, I found two basic ways: - buy 2 cheap webcams and DIY - buy a stereo camera
For what I understood little variations in distance and inclination can easily compromise the diff map and so the DIY version might end up requiring constant calibrations, however on the other end, so buying "professional" stereo camera range from 500 euro to infinite.
For the moment I trying something in between, like the minoru 3d, however the overall performance of the camera looks a bit poor also because it's a 2009 product, however I can't find any more recent product offering a similar solution.
Can you suggest me what would be the best way/product/guide to archive decent results without spending a fortune ?
Thank you very much :)
I am a huge fan of the ZED it is easy to use and comes with pre built modules to use with opencv and some great examples, but at 500$ it might be out of your price range. I have had plenty of success with two cheap webcams, thee best thing to do it mount them on somthing like a metal bar after removing any pivot mechanism, so they will always be aligned.
  • $\begingroup$ Yeah, i've seen the ZED, I think it's going to be my first "expensive" camera if I can't do with cheaper ones... for a cheaper test what have you been using ? $\endgroup$ – Cesar Jun 4 '15 at 19:35
  • $\begingroup$ honestly just webcams on a stick they work great just more of a pin to get working $\endgroup$ – Mark Omo Jun 4 '15 at 19:37
  • $\begingroup$ thanks you very much, I'll give it a try and see what's up :) $\endgroup$ – Cesar Jun 4 '15 at 19:58
  • $\begingroup$ Glad I could help! Feel free to ask more questions were here to help $\endgroup$ – Mark Omo Jun 4 '15 at 20:27
