I try to communicate two different machines using ROS, but they have different ROS version. Is there any compatibility issue? I have a robot installed with Ubuntu 12.04 and ROS Groovy, and a laptop with Ubuntu 14.04 and ROS Indigo. The two machines are connected by an Ethernet cable. I could ping each other from both machines and the ROS_MASTER_URI variables are exported to be the same. However, my robot cannot find the master node on my laptop.
I guess it is due to compatibility issue between the two ROS versions. Is there any solution besides reinstall the whole system? Thanks a lot!
Originally posted by fina12 on ROS Answers with karma: 3 on 2016-05-11
Nodes from Groovy should be able to connect to an Indigo ROS master, and Indigo nodes should be able to connect to the Groovy ROS master.
There have been some message format changes between Groovy and Indigo, so there will be message types and topics that don't work between nodes of different versions. You'll usually see an error message about MD5sum mismatches from one or both nodes involved when this happens.
You should consult the Hydro migration guide and Indigo migration guide for specific package changes between versions.
Originally posted by ahendrix with karma: 47576 on 2016-05-12
Comment by curranw on 2016-05-12:
Just to add an interesting note to this: You can even do this with different operating systems. We did this when the Kinect 2 had Windows-only drivers. As long as the messages have the same format, everything works fine.
Comment by fina12 on 2016-05-12:
Problem solved. Thanks a lot!
