I have a camera which gives me images which are already rectified. I'm writing the ROS driver for it and I'm wondering what I should do with the camera_info message. Should I :
  • Calibrate the camera and publish the intrinsic parameters in the camera_info message
  • Calibrate the camera and publish the projection matrix but set the distortion parameters to 0
  • Not calibration and set all the camera_info parameters to 0
For the record, I do not have access to the prerectified image, only the final result.
Originally posted by JustinBlack02 on ROS Answers with karma: 131 on 2016-05-02
  • Setting the first element of the intrinsic matrix, K[0], to 0.0 should be accepted by the various image pipeline components as a "raw" or uncalibrated image. That would probably work fine for your device.
  • Alternatively, you could run the ROS calibration tool and publish its calibration. I would expect that to work OK with your already-calibrated images, although you should experiment to confirm that guess. Edit: experiment revealed unsatisfactory results.
Originally posted by joq with karma: 25443 on 2016-05-05
Comment by JustinBlack02 on 2016-05-05:
Thanks!
For the second part of your answer, I did try but after the second rectification everything looks a lot worse .
Comment by joq on 2016-05-05:
Good to know, thanks for following up.
It's not customary to close a question just because it has an acceptable answer. I'll re-open it.
