I would like publish a continuous flow messages on a topic from the terminal. In order to do that I use the --rate argument of the rostopic tool. However my message type contains a header field that I would like to fill automatically.
The ros documentation says that you can fill the header stamp automatically (ref) in this way:
$ rostopic pub my_topic my_msgs/StampedMsg '{header: auto}'
However, it looks that the timestamp field does not update when it is used with the --rate parameter. Instead it remains constant with the stamp of the first message of the flow.
$ rostopic pub my_topic my_msgs/StampedMsg '{header: auto}' --rate 5
Is there any way to use rostopic so that the stamp field is automatically filled and dynamically updated?
Originally posted by Pablo Iñigo Blasco on ROS Answers with karma: 2982 on 2016-04-26
In the link 'ros_comm#55' of the post of Martin, there is the solution.
Add -s option in the rostopic pub command line.
rostopic pub my_topic my_msgs/StampedMsg '{header: auto}' --rate 5 -s
Originally posted by bigbellmercy with karma: 86 on 2019-02-27
Yes, that's a bug in rostopic that I reported about 5 years ago: ros_comm#55. So the best workaround is probably to just write a 5-line python script that does the publishing.
Originally posted by Martin Günther with karma: 11816 on 2016-04-27
