I know this question has been asked many times, but I really wanted to understand what was wrong with my commands and environment setup. I tried solutions from other sources but none worked in my case.
I installed ROS indigo on Raspberry Pi 3 following this tutorial http://wiki.ros.org/ROSberryPi/Installing%20ROS%20Indigo%20on%20Raspberry%20Pi
And I am going through beginner tutorials, currently on section "Understanding ROS Nodes" with following link: http://wiki.ros.org/ROS/Tutorials/UnderstandingNodes
As I ran command rosrun turtlesim turtlesim_node, the terminal gave following output error: [rosrun] Couldn't find executable named turtlesim_node below /home/pi/ros_catkin_ws/src/ros_tutorials/turtlesim
I have added source /opt/ros/indigo/setup.bash; source ~/ros_catkin_ws/devel/setup.bash;in the end of ~/.bashrc file.
Also, my working space is ros_catkin_ws.
As I run rospack profile, it produces following output:
0.065189 /home/pi/ros_catkin_ws/src
0.029168 * /opt/ros/indigo/share
0.020896 /home/pi/ros_catkin_ws/src/ros_comm
0.008227 /home/pi/ros_catkin_ws/src/ros_control
0.005578 /home/pi/ros_catkin_ws/src/ros
0.003114 /home/pi/ros_catkin_ws/src/roscpp_core
0.002664 /home/pi/ros_catkin_ws/src/joystick_drivers
0.002548 /home/pi/ros_catkin_ws/src/common_msgs
0.002168 /home/pi/ros_catkin_ws/src/ros_tutorials
0.001130 /home/pi/ros_catkin_ws/src/diagnostics
0.000709 /home/pi/ros_catkin_ws/src/ros_comm_msgs
As I run rospack find turtlesim, it successfully find location of the package at /home/pi/ros_catkin_ws/src/ros_tutorials/turtlesim
So can someone give me detailed instructions on how to follow the tutorial and find the executables? Thank you so much.
Originally posted by GarethZhang on ROS Answers with karma: 1 on 2016-04-25
The location of the turtlesim package is in the dir. opt/ros/indigo/share, you can search turtlesim_node in your catkin workspace to make sure where there is a executable or not.
Originally posted by langqy with karma: 16 on 2016-04-25
