Hi all,
I have an AR drone with a Lidar attached. I have hector_slam running giving out a position estimate for the drone which is working fine. I also have a PTAM node running which is also spitting out a position estimate.
What is the best way to combine these position estimates to give a best guess for the location of the drone?
Originally posted by andythepandy93 on ROS Answers with karma: 55 on 2016-04-10
Comment by al-dev on 2016-04-10:
Are you using these 2 SLAM algorithms to estimate motion increments (local pose estimation) or to estimate a "fused map"+pose within the fused map (map+global pose estimation) ?
Comment by andythepandy93 on 2016-04-10:
hector_slam is building up a map as it goes along and giving out that map and a pose estimate. The PTAM slam is working out increments I think as it gets its key points when it starts up and then goes from there, (it also uses control inputs for the drone for the pose estimate)
It seems that you are running 2 SLAM algorithms in parallel which is a bit confusing, but you could still try one of the following :
  1. The output of SLAM is {map+global pose estimate} so you actually have 2 different maps with 2 different global pose estimates. There is no trivial way to fuse all these directly AFAIK. I guess if you are not interested in fusing the maps, you could take one of them as a reference and then just fuse the global pose estimates through an EKF/UKF via the robot_localization package.
  2. If one of these 2 SLAM algorithms was using odometry as an input and you already had a source of odometry (e.g wheel odometry, visual odometry...) you could try to use the other SLAM algorithm to provide an alternative odometry estimate, and then fuse it through an EKF/UKF with your existing odometry. Then give the "improved" (?) odometry estimate to your second SLAM algorithm.
For instance, hector_slam can provide such an odometry estimate via the undocumented pub_odometry parameter, see this question
The problem here is that none of the two SLAM algorithms you mentioned - I am less familiar with PTAM though - use any source of odometry... You could try to modify hector_slam to use odometry but that requires some work, see this question. As for PTAM, I don't know.
Originally posted by al-dev with karma: 883 on 2016-04-11
Comment by andythepandy93 on 2016-04-11:
Okay great there's lots to think about in there, thanks. I had heard of the pub_odometry parameter but not looked into it so will give that a look. Also just looked at the robot_localization package and it looks good. Cheers!
