I had compile the Leddar ROS package successfully, after that I running the command roslaunch leddar leddar.launch and it will show me :
... logging to /home/leddar/.ros/log/04b08b28-fb0f-11e5-8fba-c03fd56476ff/roslaunch-leddar-desktop-29633.log
Press Ctrl-C to interrupt
started roslaunch server http://leddar-desktop:36972/
SUMMARY
PARAMETERS
 * /leddar/fov: 45.0
 * /leddar/frame: leddar
 * /leddar/range: 50.0
 * /leddar/serial:
 * /rosdistro: indigo
 * /rosversion: 1.11.16
NODES
    leddar (leddar/leddar)
core service [/rosout] found
process[leddar-1]: started with pid [29651]
[ INFO] [1459850056.151109908]: Connected to default
[ INFO] [1459850056.165976987]: Reconfiguring...
[ INFO] [1459850056.175064564]: Streaming...
[leddar-1] process has died [pid 29651, exit code -7, cmd /home/leddar/catkin_ws/devel/lib/leddar/leddar __name:=leddar __log:=/home/leddar/.ros/log/04b08b28-fb0f-11e5-8fba-c03fd56476ff/leddar-1.log].
log file: /home/leddar/.ros/log/04b08b28-fb0f-11e5-8fba-c03fd56476ff/leddar-1*.log
[leddar-1] restarting process
process[leddar-1]: started with pid [29697]
[ INFO] [1459850070.122849882]: Connected to default
[ INFO] [1459850070.138432672]: Reconfiguring...
[ INFO] [1459850070.145432446]: Streaming...
[leddar-1] process has died [pid 29697, exit code -7, cmd /home/leddar/catkin_ws/devel/lib/leddar/leddar __name:=leddar __log:=/home/leddar/.ros/log/04b08b28-fb0f-11e5-8fba-c03fd56476ff/leddar-1.log].
the leddar ros package I was git clone from : https://github.com/mcgill-robotics/ros-leddar
anyone know how to solve it? Thank you!
Originally posted by Zero on ROS Answers with karma: 104 on 2016-04-05
Comment by mgruhler on 2016-04-05:
I'm guessing, this is pretty much this question...
Comment by Zero on 2016-04-05:
that problem I just simply use roslaunch leddar leddar.launch
instead of github provide one. Then the problem was solved. now is that I can connect the leddar eva kit but just a while it will died then reconnect back again, repeating the problem until totally failure
Hello! I had the same problem. I think that my Leddar was configured so that its measurement rate was max. Maybe too many data sent caused troubles... So, I changed 'Accumulation' and 'Oversampling' in order to decrease the measurement rate (see user guide of Leddar Evaluation Kit p28) and it fixed it. To change the configuration, I modified src/leddar/src/leddar.cpp : Search for LeddarSetProperty(Handler, PID_ACCUMULATION_EXPONENT, 0, config.accumulations); and LeddarSetProperty(Handler, PID_OVERSAMPLING_EXPONENT, 0, config.oversampling); I changed config.accumulations by 7 and config.oversampling by 3 so that measurement rate becomes 12.5 Hz. I am looking for a smarter way to configure my Leddar, but it's working for now.
Originally posted by MARAUDER with karma: 36 on 2016-05-23
Comment by Zero on 2016-05-23:
ok,I will try it when I back to my school. Thank you so much.
