I'm installing ROS Indigo on Jetson TK1 and it's fast enough for RVIZ so I was wanting to install the desktop version but only base is available.
How can I get a list of the packages in Desktop so that I can install them manually? This is all on Ubuntu 14.04 "Trusty" on ARM Jetson TK1
Originally posted by jacksonkr_ on ROS Answers with karma: 396 on 2016-04-04
You probably can't install the desktop metapackage on ARM because not all of the packages in it build for ARM.
The full list of which packages are currently available on ARM and which aren't is on the ARM build status page
Originally posted by ahendrix with karma: 47576 on 2016-04-04
Comment by Mekateng on 2018-05-02:
Hi Mr. @ahendrix . I wan to install ros on my jetson tx1(ubuntu 16.04). but i dont know which to install. ros base or ros desktop. please help me this situation
Comment by ahendrix on 2018-05-02:
All of the packages installed by base are also installed by desktop. Desktop also includes GUI (graphical user interface) packages that are only useful if you have a monitor attached to your TX1.
I would start with base, and if you find that you need the additional GUI packages, you can install individual packages or the desktop variant later.
Comment by Mekateng on 2018-05-03:
Thank you very much
The contents of all distribution metapackages is documented in REP-142:
 - ros_base:
    extends: [ros_core]
    packages: [actionlib, angles, bond_core, class_loader,
               dynamic_reconfigure, nodelet_core,
               pluginlib]
and:
 - desktop:
     extends: [robot, viz]
    packages: [common_tutorials, geometry_tutorials, ros_tutorials,
               roslint, urdf_tutorials, visualization_tutorials]
- desktop_full:
    extends: [desktop, perception, simulators]
You can use the rosinstall_generator to generate a .rosinstall file for you. That would include the necessary information.
Originally posted by gvdhoorn with karma: 86574 on 2016-04-04
