Hello,
I'm in the process of using a stereo camera that generates a pointcloud2 sensor message. I can open it up in rviz, and view the pointcloud. now I want to try and use the uint8[] data for a system I'm working on. I have a Python subscription node that can subscribe to the proper topic as well as print the data inside the script. I just need to know how to get from this huge data string to a useable (x, y, z) format or numpy array in camera space for me to do something useful for it.
I did stumble across python-pcl by strawlab, but I'm not sure if that's what I need to use, or what?
Looking forward to some help!
Thanks in advance!
Originally posted by atomoclast on ROS Answers with karma: 151 on 2016-03-31
Post score: 5
http://answers.ros.org/question/202787/using-pointcloud2-data-getting-xy-points-in-python/
http://ros-by-example.googlecode.com/svn/trunk/rbx_vol_1/rbx1_apps/nodes/follower2.py
import sensor_msgs.point_cloud2
for point in sensor_msgs.point_cloud2.read_points(msg, skip_nans=True):
            pt_x = point[0]
            pt_y = point[1]
            pt_z = point[2]
Originally posted by lucasw with karma: 8729 on 2016-04-02
Post score: 5
Comment by Meric on 2019-03-22:
I belive x y and z cordinates are not same with the frame of the Camera, I am using this lines of code as below:
    number_of_sampling = 30
    x_total = 0
    y_total = 0
    z_total = 0
    counter = 0
    for point in sensor_msgs.point_cloud2.read_points(data, skip_nans=True):
        y_total += point[0]
        z_total += point[1]
        x_total += point[2]
##        print x_total, y_total, z_total
        counter += 1
        if counter == number_of_sampling: break
    x_average = x_total / number_of_sampling
    y_average = -1*y_total / number_of_sampling
    z_average = -1*z_total / number_of_sampling
In other words 0 index is Y 1st index is Z and 2nd index is X
I know I'm a little late here, but a function is included in ros_numpy package for this exact purpose. http://docs.ros.org/kinetic/api/ros_numpy/html/point__cloud2_8py_source.html
An example implementation:
import ros_numpy
xyz_array = ros_numpy.point_cloud2.get_xyz_points(pointcloud2_array)
Post score: 6
