So I am trying to calibrate Baxter's arms to have an accurate control(get rid of the unnecessary drifts of joints). On visual inspection I see that after running the script all the joints do get calibrated but suddenly at a very specific position every time(I believe that is just after calibrating W2), the arms disables itself with above error. I know the arm isn't calibrated properly because when I hold the cuff off button (zero gravity mode) the arm pulls back itself (a sign of poorly calibrate arm). Same thing happens when I reboot Baxter and run the Tare example. Any suggestion what I should do?
Also does having a torque control over any position/ velocity control or torque control alone help in avoid the drifting of arm. The reason I ask this is I when I command the arm to move to a position (I use IKsolver) it tries to reach there but the motion is not precise. It drifts off from the actual position and recovers after a sec or two to the original position. Maybe with torque control I can have a more accurate movement. I might be wrong. Any help much appreciated.
Originally posted by rdhn on ROS Answers with karma: 51 on 2016-03-27
Minute leveling adjustment and running the calibration and tare example a couple of time worked for me.
Originally posted by rdhn with karma: 51 on 2016-04-15
Comment by gvdhoorn on 2016-04-16:
Have you contacted Rethink about this? Seems like a question for their support department.
