Hi There,
I've spent a while now trying to setup a robust sphere detection using RANSAC segmentation tools in PCL. The point clouds I'm working with are created by a scanning lidar and I'm trying to detect basket balls at the moment. Here's a picture showing the type of failed sphere detection that is happening most of the time.
image description
I can see how the RANSAC algorithm can make such a false positive when it's working with points alone, so I'm trying to use the point normals as well which I think should prevent these false positives. I've calculated the normals for the point cloud and I'm now using the pcl::SACSegmentationFromNormals object to try the same sphere detection, but it's resulting in exactly the same false positives as before. The only thing I can assume is that for some reason the normals are not being taken into consideration. I've visualized the normals, and they are correctly calculated.
Here's the code I'm using;
  ROS_INFO("Polpulating new point cloud");
  // generate point cloud for this mesh
  scanMesh->populatePointCloud();
  boost::shared_ptr<pcl::PointCloud<pcl::PointXYZRGBNormal> > cloud2(scanMesh->cloud);
  pcl::ModelCoefficients::Ptr coefficients(new pcl::ModelCoefficients);
  pcl::SACSegmentationFromNormals<pcl::PointXYZRGBNormal, pcl::PointXYZRGBNormal> segmentation;
  segmentation.setInputCloud(cloud2);
  segmentation.setInputNormals(cloud2);
  segmentation.setModelType(pcl::SACMODEL_SPHERE);
  segmentation.setMethodType(pcl::SAC_RANSAC);
  segmentation.setDistanceThreshold(0.01);
  segmentation.setOptimizeCoefficients(true);
  segmentation.setRadiusLimits(0.1, 0.15);
  segmentation.setEpsAngle(15 / (180/3.141592654));
  segmentation.setMaxIterations(1000000);
  pcl::PointIndices inlierIndices;
  segmentation.segment(inlierIndices, *coefficients);
  if (inlierIndices.indices.size() == 0)
    ROS_INFO("RANSAC nothing found");
  else
    ROS_INFO("RANSAC found shape with [%d] points", (int)inlierIndices.indices.size());
    for (int c=0; c<coefficients->values.size(); ++c)
        ROS_INFO("Coeff %d = [%f]", (int)c+1, (float)coefficients->values[c]);
    // mark the found inliers in green
    for (int m=0; m<inlierIndices.indices.size(); ++m)
        cloud2->points[inlierIndices.indices[m]].r = 0;
        cloud2->points[inlierIndices.indices[m]].g = 255;
        cloud2->points[inlierIndices.indices[m]].b = 0;
Does anyone have any experience using the pcl::SACSegmentationFromNormals class for sphere detection?
Thanks,
Originally posted by PeteBlackerThe3rd on ROS Answers with karma: 9529 on 2016-03-21
Post score: 4
I've managed to get to the bottom of this one.
I needed to change,
to
segmentation.setModelType(pcl::SACMODEL_NORMAL_SPHERE);
RANSAC was still using the basic sphere model, not the sphere with normals. This is picking up sphere's really well now.
Originally posted by PeteBlackerThe3rd with karma: 9529 on 2016-03-24
Comment by Mahe on 2016-10-13:
could you share whole code what you have done, I am trying here to detect a cube,
Comment by PeteBlackerThe3rd on 2017-09-26:
Unfortunately a cube in not a simple primitive like a sphere so it can't be detected directly with RANSAC. A cube is effectively 6 faces, with several requirements. 3 pairs must be parallel and equidistant and each face must be a right angles to all others except for it's parallel partner.
