Hi to all,
I'm kind of new to ROS and I'm having a problem while compiling the catkin workspace on my laptop. I'm using ROS Indigo on Ubuntu 14.04, and I'm trying to compile the irobotcreate2ros
package (https://github.com/MirkoFerrati/irobotcreate2ros).
It requires the packages serial
and joy
to be installed. The problem is that when I compile the workspace, I received the following error:
CMakeFiles/basic_commands.dir/src/irobotcreate2/OpenInterface.cpp.o: In function irobot::OpenInterface::getSensorPackets(int):
OpenInterface.cpp:(.text+0xf3c): undefined reference to serial::Serial::waitReadable()
CMakeFiles/basic_commands.dir/src/irobotcreate2/OpenInterface.cpp.o: In function irobot::OpenInterface::streamSensorPackets():
OpenInterface.cpp:(.text+0x12a5): undefined reference to serial::Serial::waitReadable()
collect2: error: ld returned 1 exit status
make[2]: [/home/myhome/Projects/ros/indigo/catkin_ws/devel/lib/irobotcreate2/basic_commands] Error 1
make[1]: [irobotcreate2ros/CMakeFiles/basic_commands.dir/all] Error 2
make[1]: Waiting for unfinished jobs....
CMakeFiles/irobotcreate2_lightweight.dir/src/irobotcreate2/OpenInterface.cpp.o: In function irobot::OpenInterface::getSensorPackets(int):
CMakeFiles/irobotcreate2_lightweight.dir/src/irobotcreate2/OpenInterface.cpp.o: In function irobot::OpenInterface::streamSensorPackets():
make[2]: [/home/myhome/Projects/ros/indigo/catkin_ws/devel/lib/irobotcreate2/irobotcreate2_lightweight] Error 1
make[1]: [irobotcreate2ros/CMakeFiles/irobotcreate2_lightweight.dir/all] Error 2
CMakeFiles/irobotcreate2.dir/src/irobotcreate2/OpenInterface.cpp.o: In function irobot::OpenInterface::getSensorPackets(int):
CMakeFiles/irobotcreate2.dir/src/irobotcreate2/OpenInterface.cpp.o: In function irobot::OpenInterface::streamSensorPackets():
make[2]: [/home/myhome/Projects/ros/indigo/catkin_ws/devel/lib/irobotcreate2/irobotcreate2] Error 1
make[1]: [irobotcreate2ros/CMakeFiles/irobotcreate2.dir/all] Error 2
make: [all] Error 2
Invoking "make" failed
This makes me think that probably the compiler is not able to find the serial package. Now:
- The problem with serial is only related to the
waitReadable()
function, as if I comment it from the code, the rest of serial references do not rise any compilation error, and the process ends without problem (I've the right configuration of CMake. I know also because I'm using the same CMakeFile I used on other machines, that is the one provided within the package). - I compiled this package (
irobotcreate2ros
) on other machines without problem, so maybe there's a wrong version of serial installed on my laptop. I went digging around on the internet, and I found that previous version of serial (http://rosindex.github.io/p/serial/), e.g. until v1.1.7, didn't have anywaitReadable()
method. I then checked which version was installed, and it says 1.2.1. - To be completely sure, I also went through the code of
serial.h
in/opt/ros/indigo/include/serial/
to see if there was thewaitReadable()
method, and it's there (although there's just the function signature, of course). - Lastly, I thought it might depend on the
libserial
library, that I have installed (v0.6.0~rc1-0ubuntu4), but it doesn't seem to be related.
Now, I really don't know why the compiler is not able to solve that reference. I tried unistalling and reinstalling serial, but nothing changed. Any suggestion?
--- edit ---
The CMakeLists.txt
file I'm using is exactly the same reported in this git repository https://github.com/MirkoFerrati/irobotcreate2ros/blob/master/CMakeLists.txt
Thanks
Originally posted by McKracken82 on ROS Answers with karma: 73 on 2016-03-18
Comment by joq on 2016-03-18:
Would you edit your question adding the relevant parts of your CMakeLists.txt
Comment by William on 2016-03-18:
I usually see this kind of problem when you have an older version of the library hanging around on your system somewhere but you've compiled your code against the newer headers. For example: https://github.com/wjwwood/serial/issues/126
Comment by McKracken82 on 2016-03-21:
I've added the CMakeList file. William, I think that's the problem. I realized I've different version of libserial.so around the system, but I'm not getting where catkin is getting the serial package when compiling, nor the libserial.so to link with. I've moved them around, but nothing changed.
