I'm working through the first tutorial on using MoveIt with CRAM, and I'm able to load the tutorial module, query the state of the robot, etc. without problems.
However, when I try to move the robot with the line
(move-link-pose "r_wrist_roll_link" "right_arm" tuti:*pose-mid*)
the REPL shows
[(MOVEIT) ERROR] 1457223557.388: Empty actionlib response.
and the MoveIt terminal window says
[ERROR] [1457223552.356453336]: Exception thrown when deserializing message of length [5034] from [/tutorial-client]: Buffer Overrun
What might be the problem? I thought that maybe some piece of CRAM code was built against an old version of moveit_msgs, but I've tried catkin_make-ing in a clean workspace with no change.
Originally posted by abestick on ROS Answers with karma: 18 on 2016-03-05
I just tried out the tutorial and the call succeeded for me.
Which version of cram_moveit and cram_tutorials are you using?
The link to the repository in the tutorial was a bit outdated, so I updated it now (and also cleaned up the code in the repo a bit). If you're using cram_moveit version 0.2.1 (see package.xml), then cloning from the updated link in the tutorial might help.
Originally posted by gaya with karma: 311 on 2016-03-07
Comment by abestick on 2016-03-07:
I was indeed using 0.2.1, and updating the cram_tutorials package as you suggested fixed it! Thanks!
