1 - Generated the .pgm files through gmapping using LIDAR data.
-- One with partial map
-- One with map of the whole area
Trying to:
2 - Use opencv to compare the maps
3 - To get the coordinates of the lidar at the partial map
-- For pinpointing this lidar in the full map
Above is the brief summary of the problem encountered. Anyone may have any advice or a direct solution.
Please and Thank You viewers.
Originally posted by Avonic on ROS Answers with karma: 11 on 2016-02-27
A variant of what you describe is implemented in the hector_mapstitch package. It can be used to align two maps with each other. When both robots run a SLAM system, their relative poses can be computed from the transform between the two maps and their location in their respective maps.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2016-02-27
Comment by Avonic on 2016-03-01:
I am getting quite confuse with the ros_mapstitch function. Can you please advice me on that thank you.
