I've modified the turtlesim tutorial to control some servos from a ps3 controller, and everything works fine when everything is running from my laptop. Now I want to move the part/file that actually do the moving of the servos over to a RPi.
I've added
export ROS_MASTER_URI=http://Yoda.local:11311
to the .bashrc on both nodes.
rostopic list/info/type displays the same info on both laptop and RPi, but when I try to get any actual data out, the RPi doesn't receive anything on rostopic echo/hz
I've tried running
rostopic pub -r 10 /robonova3/cmd_vel geometry_msgs/Twist '{linear: {x: 0.1, y: 0.0, z: 0.0}, angular: {x: 0.0,y: 0.0,z: 0.0}}'
on both machines, but its only picked up locally, not by the other machine...
Any suggestions?
Originally posted by Pengatom on ROS Answers with karma: 15 on 2016-02-18
Comment by NEngelhard on 2016-02-18:
Have you also set the ROS_IP on both computers?
This can happen when ROS_IP or ROS_HOSTNAME (only one of the two needed) are not set correctly on both machines. See also lEnvironmentVariables or this Q/A, Searching for "ROS_IP" or "ROS_HOSTNAME" here or on google should also provide sufficient info to fix this issue.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2016-02-18
Comment by Pengatom on 2016-02-19:
Voila! Thanks Should've been better explained that this is needed. In the tutorial it's only mentioned as something to add if one cannot ssh to the machine - which I could...
Comment by Procópio on 2016-02-25:
you are welcome to edit the wiki to better explain that ;)
