Hi, I am sending velocity command to gazebo model but it only reflects 35% of commanded velocity. I tried to tune PID gain in config file but it doesn't affect anything. In xacro file also, changing mechanical reduction doesn't seem to work. Does anybody have idea how to fix it so that I can get the velocity what I am commanding to the model?
Thanks.
Originally posted by cybodroid on ROS Answers with karma: 234 on 2016-02-16
Comment by Arowana on 2016-02-16:
Please give us more information on what node are you using. If you use a ros controller maybe the config from cmd_vel to hardware is wrong. If you use directly a gazebo controller maybe their is a transmission gearing down the speed
