i am trying to connect my arduino with ROS i am following the hello world tutorial: http://wiki.ros.org/rosserial_arduino/Tutorials/Hello%20World i am using ROS Jade
when i come to the step following step: rosrun rosserial_python serial_node.py /dev/ttyUSB0
i receive an error of serial port as: [ERROR] [WallTime: 1455616377.748461] Error opening serial: could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'
i know its an error of the serial port but i am not able to solve it plz help me i really need help with this matter.
Originally posted by naqi.nick on ROS Answers with karma: 62 on 2016-02-16
Comment by mgruhler on 2016-02-17:
The error says that /dev/ttyUSB0 does not exist. Did you check if you find this port with ls /dev/ttyUSB0? Otherwise, you need to replace ttyUSB0 with your correct serial port, as it says in the tutorial.
Comment by naqi.nick on 2016-02-19:
thank you but how do I find the correct serial port? I want to use Bluetooth for the communication
A simple way to check the correct serial port is using the Arduino IDE , on the tools menu go to "Port" and it shows the current port where Arduino is connect. Once you check the arduino the _port:= param has to be the same
Originally posted by jcardenasc93 with karma: 70 on 2016-03-18
Comment by naqi.nick on 2016-04-09:
thank you that solved the problem
