Hi, I am trying to use the velodyne drivers in ROS indigo on my Ubuntu VM running inside Virtualbox. I followed the instructions from here http://wiki.ros.org/velodyne/Tutorials/Getting%20Started%20with%20the%20HDL-32E. Unfortunately, even after using the vlp16_points.launch and the vlp16 calibration file, I am unable to see the pointcloud in rviz. I get the fixed frame velodyne not found error in rviz. After digging google for a while I decided to use Wireshark to check if I receive the packets. I could not see the UDP packets in Wireshark (launched as superuser) in my Ubuntu VM. But, when I tried doing the same with Windows, I was able to see the UDP packets. In my Ubuntu VM, I could only see TCP and HTTP under IPV4 unlike UDP in Windows. Is it because of the network config in VM? Do I need to change some settings in it?
Originally posted by krishnaece1505 on ROS Answers with karma: 103 on 2016-02-15
I have no experience with network configuration for a virtual machine, but from the fact that Windows sees the packets and Ubuntu does not, the problem is almost certainly some kind of Virtualbox issue.
Originally posted by joq with karma: 25443 on 2016-02-15
