Hi,
I am trying out the tutorials on SMACH in ros-indigo.
I am trying to run this following SMACH program state_machine_simple.py
#!/usr/bin/env python
import roslib; roslib.load_manifest('smach_tutorials')
import rospy
import smach
import smach_ros
# define state Foo
class Foo(smach.State):
    def __init__(self):
        smach.State.__init__(self, outcomes=['outcome1','outcome2'])
        self.counter = 0
    def execute(self, userdata):
        rospy.loginfo('Executing state FOO')
        if self.counter < 3:
            self.counter += 1
            return 'outcome1'
        else:
            return 'outcome2'
# define state Bar
class Bar(smach.State):
    def __init__(self):
        smach.State.__init__(self, outcomes=['outcome2'])
        rospy.loginfo('Executing state BAR')
        return 'outcome2'
# main
def main():
    rospy.init_node('smach_example_state_machine')
    # Create a SMACH state machine
    sm = smach.StateMachine(outcomes=['outcome4', 'outcome5'])
    # Open the container
    with sm:
        # Add states to the container
        smach.StateMachine.add('FOO', Foo(),
                               transitions={'outcome1':'BAR',
                                            'outcome2':'outcome4'})
        smach.StateMachine.add('BAR', Bar(),
                               transitions={'outcome2':'FOO'})
    # Execute SMACH plan
    outcome = sm.execute()
if __name__ == '__main__':
    main()
But when I execute it I am getting this error
  File "state_machine_simple.py", line 9, in <module>
AttributeError: 'module' object has no attribute 'State'
I don't know how to solve this error... kindly help me out....
Originally posted by Niranjan on ROS Answers with karma: 51 on 2016-02-15
Comment by spmaniato on 2016-02-15:
In a terminal, type python and then try: from smach import State Does that result in an error too?
Comment by Niranjan on 2016-02-15:
Hi, I tried that its not showing error.... So I tried including from smach import State statement in the program... now its working fine.. thank you..
Adding from smach import State statement in the program solves this problem
Originally posted by Niranjan with karma: 51 on 2016-02-22
