I'm a complete beginner in robotics with background in programming...
I started thinking about a robot project yesterday and want to order some motors to test with. I saw the specs for the motors, torque etc, and I think I remember enough physics from high school to do simple calculations. For example, if the motor rotates an arm, then given the torque and the length of the arm, how much could it lift? Also, if it doesn't lift it straight up, but at an angle, I could with a bit of thinking tweak the calculations a bit... If there would be several joints attached to each other, the calculations would be more complex, but I could then probably create a program in node.js, for example, to be able to experiment with different values.
However, I would assume that these kinds of calculations would be very common when designing robots. So I would assume there are already programs for these types of calculations created. I don't know exactly what I mean with "these types of calculations", because I don't know yet what I don't know, so would like to ask which programs are there that you guys use for making calculations when you design your robots?
Preferable they should be open source...
