I'm following the instructions for setting up ROS for Android found here. I'm installed this on Ubuntu 14.04. I've got this issue on a system with Android NDK/SDK already setup as well as a clean install of Ubuntu.
After some time the failure is CMake looking for console_bridge package at /usr/share/console_bridge which does not exist. I've tried finding info regarding this failure and installing console_bridge but at the moment I'm stumped.
After some time do_docker.sh fails with the following output:
-- ==> add_subdirectory(class_loader)
-- Boost version: 1.53.0
-- Found the following Boost libraries:
--   thread
--   system
CMake Error at /usr/share/console_bridge/cmake/console_bridge-config.cmake:12 (message):
  Library 'console_bridge' in package console_bridge is not installed
  properly
  class_loader/CMakeLists.txt:6 (find_package)
See also "/opt/roscpp_output/catkin_ws/build/CMakeFiles/CMakeOutput.log".
Invoking "cmake" failed
Installing.
make: *** No rule to make target `install'.  Stop.
build_cpp.sh /opt/roscpp_output died with error code 2
rob@rob-VirtualBox:~/ros-android-ndk/roscpp_android$ sudo apt-get install console-bridge
Reading package lists... Done
Building dependency tree
E: Unable to locate package console-bridge
rob@rob-VirtualBox:~/ros-android-ndk/roscpp_android$ sudo apt-get install console_bridge
E: Unable to locate package console_bridge
Edit: I dug further through the logs. Looks like console_bridge is failing to compile:
/opt/roscpp_output/libs/console_bridge/src/console.cpp:60:5: error: 'mutex' in namespace 'std' does not name a type
/opt/roscpp_output/libs/console_bridge/src/console.cpp: In function 'void console_bridge::noOutputHandler()':
/opt/roscpp_output/libs/console_bridge/src/console.cpp:83:43: error: 'lock_guard' is not a member of 'std'
/opt/roscpp_output/libs/console_bridge/src/console.cpp:83:59: error: 'mutex' is not a member of 'std'
/opt/roscpp_output/libs/console_bridge/src/console.cpp:83:87: error: 'struct DefaultOutputHandler' has no member named
Originally posted by bd on ROS Answers with karma: 1 on 2016-02-10
Comment by gvdhoorn on 2016-02-11:
Please don't use answers to post updates (this is not a forum), edit your original question for that (use the edit link/button for that). I've already merged your answer into your question, but please keep it in mind next time.
Sorry for the delay, I've just seen this.
We've already fixed that issue (here), it turns out, console_bridge move from using boost to using std C++11 mutex which is not currently available for the android_ndk.
If you update the repository, it should work.
Originally posted by Gary Servin with karma: 962 on 2016-04-26
