The thing is; following screenshot is from simulation, on Gazebo. (And Real robot does this too.) ekf_localization_node uses both of imu and odometry. And using only odometry causes this problem too.
I'm following this guide to tune my robot : ROS Wiki Navigation Tuning Guide I've set Decay Time to 30 and started inplace rotation.
Here is Rviz screenshot: Rviz
Odometry isn't reasonable for rotational motion.
Robot's translational motion is good and reasonable. But the rotational motion is bad for localization. What can I do for correcting odometry data? Or Are there any new issues on ekf_localization?
Thank you.
Originally posted by Orhan on ROS Answers with karma: 856 on 2016-02-08
for a real robot, I would say what causes this is a wrong wheel size and wheels distance (assuming a diff drive robot), but as the same happens in simulation, I am not sure about the reason.
Originally posted by Procópio with karma: 4402 on 2016-02-09
Ok, The problem was wheel_width parameter in the urdf. It was 0.05 and It caused two contacts under wheel: image description
I've set to 0.001 and problem solved, now odometry looks pretty good.
Originally posted by Orhan with karma: 856 on 2016-02-09
Post score: 4
