Hello!
I am new to ROS, so please bear with me. I am going through navigation tutorials of ROS listed here.
When I launch the amcl.demo file I get the following error continuously:
[WARN] [1454762481.036046933, 3051.340000000]: Timed out waiting for transform from base_link to map to become available before running costmap, tf error: . canTransform returned after 0.1 timeout was 0.1.
Due to this, the 2D pose Estimate and 2D nav goal don't work in Rviz. The Exploration, Static map, Global Costmap, Local Costmap show an error in Rviz.
Can anyone please help?
Thanks!
EDIT 1: Here is the summary of the terminal:
sri@Sri:~$ roslaunch husky_navigation amcl_demo.launch
... logging to /home/sri/.ros/log/99bc8912-cd81-11e5-9cc6-681729436688/roslaunch-Sri-16730.log
Press Ctrl-C to interrupt
started roslaunch server http://Sri:40227/
SUMMARY
PARAMETERS
 * /amcl/gui_publish_rate: 10.0
 * /amcl/kld_err: 0.05
 * /amcl/kld_z: 0.99
 * /amcl/laser_lambda_short: 0.1
 * /amcl/laser_likelihood_max_dist: 2.0
 * /amcl/laser_max_beams: 60
 * /amcl/laser_max_range: 12.0
 * /amcl/laser_model_type: likelihood_field
 * /amcl/laser_sigma_hit: 0.2
 * /amcl/laser_z_hit: 0.5
 * /amcl/laser_z_max: 0.05
 * /amcl/laser_z_rand: 0.5
 * /amcl/laser_z_short: 0.05
 * /amcl/max_particles: 2000
 * /amcl/min_particles: 500
 * /amcl/odom_alpha1: 0.2
 * /amcl/odom_alpha2: 0.2
 * /amcl/odom_alpha3: 0.2
 * /amcl/odom_alpha4: 0.2
 * /amcl/odom_alpha5: 0.1
 * /amcl/odom_frame_id: odom
 * /amcl/odom_model_type: diff
 * /amcl/recovery_alpha_fast: 0.0
 * /amcl/recovery_alpha_slow: 0.0
 * /amcl/resample_interval: 1
 * /amcl/transform_tolerance: 1.0
 * /amcl/update_min_a: 0.2
 * /amcl/update_min_d: 0.25
 * /amcl/use_map_topic: True
 * /move_base/DWAPlannerROS/acc_lim_th: 3.2
 * /move_base/DWAPlannerROS/acc_lim_x: 2.5
 * /move_base/DWAPlannerROS/acc_lim_y: 0
 * /move_base/DWAPlannerROS/latch_xy_goal_tolerance: False
 * /move_base/DWAPlannerROS/max_rot_vel: 1.0
 * /move_base/DWAPlannerROS/max_trans_vel: 0.5
 * /move_base/DWAPlannerROS/max_vel_x: 0.5
 * /move_base/DWAPlannerROS/max_vel_y: 0
 * /move_base/DWAPlannerROS/min_rot_vel: 0.2
 * /move_base/DWAPlannerROS/min_trans_vel: 0.1
 * /move_base/DWAPlannerROS/min_vel_x: 0.0
 * /move_base/DWAPlannerROS/min_vel_y: 0
 * /move_base/DWAPlannerROS/xy_goal_tolerance: 0.2
 * /move_base/DWAPlannerROS/yaw_goal_tolerance: 0.1
 * /move_base/NavfnROS/allow_unknown: True
 * /move_base/NavfnROS/default_tolerance: 0.1
 * /move_base/TrajectoryPlannerROS/acc_lim_theta: 3.2
 * /move_base/TrajectoryPlannerROS/acc_lim_x: 2.5
 * /move_base/TrajectoryPlannerROS/angular_sim_granularity: 0.02
 * /move_base/TrajectoryPlannerROS/controller_frequency: 20.0
 * /move_base/TrajectoryPlannerROS/dwa: True
 * /move_base/TrajectoryPlannerROS/escape_reset_dist: 0.1
 * /move_base/TrajectoryPlannerROS/escape_reset_theta: 0.1
 * /move_base/TrajectoryPlannerROS/escape_vel: -0.1
 * /move_base/TrajectoryPlannerROS/gdist_scale: 1.0
 * /move_base/TrajectoryPlannerROS/heading_lookahead: 0.325
 * /move_base/TrajectoryPlannerROS/heading_scoring: False
 * /move_base/TrajectoryPlannerROS/heading_scoring_timestep: 0.8
 * /move_base/TrajectoryPlannerROS/holonomic_robot: False
 * /move_base/TrajectoryPlannerROS/latch_xy_goal_tolerance: False
 * /move_base/TrajectoryPlannerROS/max_vel_theta: 1.0
 * /move_base/TrajectoryPlannerROS/max_vel_x: 1.0
 * /move_base/TrajectoryPlannerROS/meter_scoring: True
 * /move_base/TrajectoryPlannerROS/min_in_place_vel_theta: 0.2
 * /move_base/TrajectoryPlannerROS/min_vel_theta: -1.0
 * /move_base/TrajectoryPlannerROS/min_vel_x: 0.0
 * /move_base/TrajectoryPlannerROS/occdist_scale: 0.1
 * /move_base/TrajectoryPlannerROS/oscillation_reset_dist: 0.25
 * /move_base/TrajectoryPlannerROS/pdist_scale: 0.75
 * /move_base/TrajectoryPlannerROS/publish_cost_grid_pc: True
 * /move_base/TrajectoryPlannerROS/sim_granularity: 0.02
 * /move_base/TrajectoryPlannerROS/sim_time: 2.0
 * /move_base/TrajectoryPlannerROS/simple_attractor: False
 * /move_base/TrajectoryPlannerROS/vtheta_samples: 20
 * /move_base/TrajectoryPlannerROS/vx_samples: 6
 * /move_base/TrajectoryPlannerROS/xy_goal_tolerance: 0.2
 * /move_base/TrajectoryPlannerROS/yaw_goal_tolerance: 0.1
 * /move_base/base_global_planner: navfn/NavfnROS
 * /move_base/base_local_planner: dwa_local_planner...
 * /move_base/controller_frequency: 5.0
 * /move_base/global_costmap/footprint: [[-0.5, -0.33], [...
 * /move_base/global_costmap/footprint_padding: 0.01
 * /move_base/global_costmap/global_frame: map
 * /move_base/global_costmap/inflation/inflation_radius: 1.0
 * /move_base/global_costmap/obstacle_range: 5.5
 * /move_base/global_costmap/obstacles_laser/laser/clearing: True
 * /move_base/global_costmap/obstacles_laser/laser/data_type: LaserScan
 * /move_base/global_costmap/obstacles_laser/laser/inf_is_valid: True
 * /move_base/global_costmap/obstacles_laser/laser/marking: True
 * /move_base/global_costmap/obstacles_laser/laser/topic: scan
 * /move_base/global_costmap/obstacles_laser/observation_sources: laser
 * /move_base/global_costmap/plugins: [{'type': 'costma...
 * /move_base/global_costmap/publish_frequency: 3.0
 * /move_base/global_costmap/raytrace_range: 6.0
 * /move_base/global_costmap/resolution: 0.05
 * /move_base/global_costmap/robot_base_frame: base_link
 * /move_base/global_costmap/rolling_window: False
 * /move_base/global_costmap/static/map_topic: /map
 * /move_base/global_costmap/static/subscribe_to_updates: True
 * /move_base/global_costmap/track_unknown_space: True
 * /move_base/global_costmap/transform_tolerance: 0.5
 * /move_base/global_costmap/update_frequency: 4.0
 * /move_base/local_costmap/footprint: [[-0.5, -0.33], [...
 * /move_base/local_costmap/footprint_padding: 0.01
 * /move_base/local_costmap/global_frame: odom
 * /move_base/local_costmap/height: 10.0
 * /move_base/local_costmap/inflation/inflation_radius: 1.0
 * /move_base/local_costmap/obstacle_range: 5.5
 * /move_base/local_costmap/obstacles_laser/laser/clearing: True
 * /move_base/local_costmap/obstacles_laser/laser/data_type: LaserScan
 * /move_base/local_costmap/obstacles_laser/laser/inf_is_valid: True
 * /move_base/local_costmap/obstacles_laser/laser/marking: True
 * /move_base/local_costmap/obstacles_laser/laser/topic: scan
 * /move_base/local_costmap/obstacles_laser/observation_sources: laser
 * /move_base/local_costmap/plugins: [{'type': 'costma...
 * /move_base/local_costmap/publish_frequency: 3.0
 * /move_base/local_costmap/raytrace_range: 6.0
 * /move_base/local_costmap/resolution: 0.05
 * /move_base/local_costmap/robot_base_frame: base_link
 * /move_base/local_costmap/rolling_window: True
 * /move_base/local_costmap/static/map_topic: /map
 * /move_base/local_costmap/static/subscribe_to_updates: True
 * /move_base/local_costmap/transform_tolerance: 0.5
 * /move_base/local_costmap/update_frequency: 4.0
 * /move_base/local_costmap/width: 10.0
 * /move_base/recovery_behaviour_enabled: True
 * /rosdistro: indigo
 * /rosversion: 1.11.16
NODES
    amcl (amcl/amcl)
    map_server (map_server/map_server)
    move_base (move_base/move_base)
core service [/rosout] found
process[map_server-1]: started with pid [16748]
process[amcl-2]: started with pid [16749]
process[move_base-3]: started with pid [16755]
[ WARN] [1454839265.612888152, 1338.590000000]: Timed out waiting for transform from base_link to map to become available before running costmap, tf error: . canTransform returned after 0.1 timeout was 0.1.
Originally posted by Srinidhi on ROS Answers with karma: 7 on 2016-02-06
Comment by Humpelstilzchen on 2016-02-07:
Error missing
Comment by Srinidhi on 2016-02-07:
Sorry. I have added the error now.
I was able to replicate this error, and got rid of it by running sudo apt-get install ros-indigo-husky-*
This installed a few additional husky packages that I didn't have, and then it all worked fine
Originally posted by nickw with karma: 1504 on 2016-02-07
Comment by Srinidhi on 2016-02-08:
Thank you so much! This worked like a charm.
Also, it should be ros instead of rose in the answer. Please rectify it. Thanks!
Comment by nickw on 2016-02-08:
well spotted - the perils of auto correct
