Hello all,
What is the board name I should use for BOARD? The following does not work.
generate_arduino_firmware(due_project
  SRCS due_project.cpp ${ROS_LIB_DIR}/time.cpp
  BOARD due
  PORT /dev/ttyACM0
I have installed DUE related stuff in IDE by Tools -> Boards Manager. I just want the arduino things to be built using catkin just like other packages. Also, I noticed that /home/peshala/arduino-1.6.5-r5/hardware/arduino/avr/boards.txt does not contain an entry for "due".
Thank you.
CS
Originally posted by ChickenSoup on ROS Answers with karma: 387 on 2016-02-01
Comment by tonybaltovski on 2016-02-01:
The due is not an avr processor, it will be under sam.
Comment by ChickenSoup on 2016-02-01:
@tonybaltovski ok I understand. So, what modifications should I make to compile and upload to DUE as in link text
hello i work for me with arduino1.6.8 i change in ros_lib the file ArduinoHardware.h #if defined(USBCON) and !(defined(USE_USBCON)) /* Leonardo support */ iostream = &Serial1;
to
#if defined(USBCON) and !(defined(USE_USBCON)) /* Leonardo support */ iostream = &Serial;
Originally posted by laazizi with karma: 16 on 2016-05-17
