I'm using two RGB cameras. They are rotated, one clock-wise and the other counter clock-wise. I'm calibrating them with Ros Stereo Calibration node which is based on OpenCv. The output I get the camera matrix, projection matrix and R and T from cv::stereoCalibrate. The stereo_image_proc node outputs the rectified images that you can see below:
image description http://i68.tinypic.com/292p3wi.png
They seem rectified, they are both "facing" the right way but there is a HUGE area of only black pixels......why is that? Does it have to do with some parameter in cv::stereoRectify that I should change?
Does it matter if I hold the calibration patter horizontally or vertically when calibrating? Could that be the issue?
Thanks for the help.
ps: This is a continuation of this question (when I was having completely black rectified images because I was doing the calibration wrong).
Originally posted by Ariel on ROS Answers with karma: 65 on 2016-01-27
It's probably due to your physical setup, please provide some description / a picture of the setup. There might be a big disparity between your images, usually those give such black areas.
Originally posted by Vincent Rabaud with karma: 1111 on 2016-01-29
Comment by Ariel on 2016-01-30:
Due to copyright issues I cannot post a picture of the setup. It's a 3d printed pair of glasses and due to it's shape and where the USB connector of the cameras, they need to be rotated so the connector is on the edge of the piece.This implies that there is a rotation of -90 and +90 for each camera
I modify the flags in calibrateCamera to CALIB_ZERO_TANGENT_DIST|CALIB_FIX_K1|CALIB_FIX_K2|CALIB_FIX_K3|CALIB_FIX_K4|CALIB_FIX_K5|CALIB_FIX_K6 and now there are no more dark areas. The remaining issue is that the orientation of the rectified images is wrong, 180.
If I understood correctly the code, it assumes that booth cameras are horizontally aligned. So, this is what I should update
