Hey together,
please see edit #1 and #2. The node for the laser scanner won't subscribe to the topics given in its parameters in the launch file. But the scan topics are published correctly.
I am trying to merge 3 laserscans together to one. For this I am trying to use the ira_laser_tools packaged and in this the laser_multi_merge. My setup is following: 3 simulated Lasers in gazebo mounted to my robot, publishing 3 different topics. I am able to view the scan topics in rviz with no problem. After launching the laser_multi_merger with following launch file part:
<node pkg="ira_laser_tools" name="laserscan_multi_merger" type="laserscan_multi_merger" output="screen">
     <param name="destination_frame" value="/ibeo_frame"/>
     <param name="cloud_destination_topic" value="/merged_cloud"/>
     <param name="scan_destination_topic" value="/scan_multi_merged"/>
     <param name="laserscan_topics" value ="scan_hokuyo1 scan_hokuyo2 scan_ibeo1" />
</node>
rostopic list comfirms that the topics /scan_hokuyo1 /scan_hokuyo2 and /scan_ibeo1 are being published. It also shows the topic /scan_multi_merged, but if I subscribe to it whit rostopic echo /scan_multi_merged the following output appears:
WARNING: no messages received and simulated time is active.
Is /clock being published?
If i enable via rqt the debug level of the node it also says that something is wrong with the /clock topic. Output of ROS_DEBUG message:
[DEBUG] [1453887963.432518126, 100.157000000]: Incoming queue full for topic "/clock".  Discarding oldest message (current queue size [0])
Can someone of you lead me to the right way and show me my faults I did?
Thanks in advance :)
Edit #1 Output of rosnode info /laserscan_multi_merger
Node [/laserscan_multi_merger]
Publications:
 * /laserscan_multi_merger/parameter_descriptions [dynamic_reconfigure/ConfigDescription]
 * /merged_cloud [sensor_msgs/PointCloud2]
 * /rosout [rosgraph_msgs/Log]
 * /laserscan_multi_merger/parameter_updates [dynamic_reconfigure/Config]
 * /scan_multi_merged [sensor_msgs/LaserScan]
Subscriptions:
 * /tf [tf2_msgs/TFMessage]
 * /tf_static [tf2_msgs/TFMessage]
 * /clock [rosgraph_msgs/Clock]
Services:
 * /laserscan_multi_merger/set_parameters
 * /laserscan_multi_merger/set_logger_level
 * /laserscan_multi_merger/get_loggers
contacting node http://aschultz-ThinkPad-T450s:42260/ ...
Pid: 21244
Connections:
 * topic: /rosout
    * to: /rosout
    * direction: outbound
    * transport: TCPROS
 * topic: /clock
    * to: /gazebo (http://aschultz-ThinkPad-T450s:33525/)
    * direction: inbound
    * transport: TCPROS
 * topic: /tf
    * to: /vehicle_state_publisher (http://aschultz-ThinkPad-T450s:55570/)
    * transport: TCPROS
 * topic: /tf_static
    * transport: TCPROS
Edit #2: Changed launch file because Laser merger is not subscribing to topics
         <param name="laserscan_topics" value ="/scan_hokuyo1 /scan_hokuyo2 /scan_ibeo1" />
 </node>
Output of rostopic info /scan_hokuyo1 /scan_hokuyo2 /scan_ibeo1
Type: sensor_msgs/LaserScan
Publishers:
 * /gazebo (http://aschultz-ThinkPad-T450s:51633/)
Subscribers:
 * /rviz (http://aschultz-ThinkPad-T450s:55316/)
rostopic info /scan_hokuyo2
Publishers:
Subscribers:
rostopic info /scan_ibeo1
Publishers:
Subscribers:
Originally posted by schultza on ROS Answers with karma: 232 on 2016-01-27
Comment by F.Brosseau on 2016-01-27:
Do you see your topics if you do a "rosnode info laserscan_multi_merger" ?
Comment by schultza on 2016-01-27:
I just see the following
rosnode list /laserscan_multi_merger
while
rostopic list
/scan_hokuyo1
/scan_hokuyo2
/scan_ibeo1
/scan_multi_merged
gives me this output. So if I understood you correctly I can't see the topics with the command
If you do a rosnode info /laserscan_multi_merger you will see which topics are published and subscribed by the node. It will allow you to check if your topics are connected to your node.
Okay. Sorry i had a copy paste error and pastet the output of rosnode list /laserscan_multi_merger which is complete nonsense :D sry. See my edit of my question for the output of rosnode info /laser_scan_merger
Seems like your node is not subscribing to your topics /scan_hokuyo1, /scan_hokuyo2 and /scan_ibeo1. Do these topics are sensor_msgs::LaserScan type?
Yeah thats correct. Do you have an idea why or should i open an new topic for that
I edited the question with the output of all rostopic info
I have no idea why, sorry. I hope that somebody else will be able to help you.
Comment by F.Brosseau on 2016-01-28:
I look into the git repository of the ira tools and maybe you can try to directly contact the team https://github.com/iralabdisco/ira_laser_tools
Comment by ahendrix on 2016-03-16:
From a quick read of the source code, you should see some kind of message once the merge node starts up; either Subscribing to topics %d or Not subscribed to any topic
3 Answers 3
I think the reason is that laser_scan_merger node was launched before gazebo started publishing the laser scan topics. If so, the laser merger would not subscribe to those laser topics.
If the laser scan merger has ever successfully subscribed to laser scan topics, you should be seeing: "Subscribing to topics x" in rosout.
One quick work around is to launch laser scan merger manually after gazebo has done launching.
Originally posted by DavidN with karma: 544 on 2016-03-16
ROS topic setup does not depend on whether the subscriber or the publisher is created first.
Nevermind; this node appears to be filtering input topics based on their type, so it DOES require topics to be published before if can subscribe to them. How broken.
This PR appears to fix the topic subscription order problem: https://github.com/iralabdisco/ira_laser_tools/pull/7
Comment by DavidN on 2016-03-16:
Exactly as ahendrix mentioned, the node actually checks if the msg type of the topic is a laser scan msg, thus ignoring the topics if it is not being published. I had a similar problem with real robot (not gazebo) with multiple lasers (more than 3)
Thanks for all your answers! As ahendrix said, the node really needs the topics to be published before starting the node. However it is not possible to start nodes in a specific order in a launch file. For now we found a solution in letting the node sleep 5 seconds before trying to get the topics (with ros::Duration(5).sleep(); directly in the constructor). This works in simulation as well at our real robot. But it is not a very clean solution. So I will try to get the PR from the link ahendrix posted and look at it again. Thanks so for :)
Originally posted by schultza with karma: 232 on 2016-03-16
Hello, I was just having this problem and thanks to your comments I got a decent solution, so I thought I should share it here. I modified the laserscan_topic_parser to retry to read the topics listed after a delay, so, here's my modification:
bool LaserscanMerger::laserscan_topic_parser(){
bool success = false;
// LaserScan topics to subscribe
ros::master::V_TopicInfo topics;
ros::master::getTopics(topics);
istringstream iss(laserscan_topics);
vector<string> tokens;
copy(istream_iterator<string>(iss), istream_iterator<string>(), back_inserter<vector<string> >(tokens));
vector<string> tmp_input_topics;
for(int i=0;i<tokens.size();++i)
        for(int j=0;j<topics.size();++j)
        if( (tokens[i].compare(topics[j].name) == 0) && (topics[j].datatype.compare("sensor_msgs/LaserScan") == 0) )
            tmp_input_topics.push_back(topics[j].name);
sort(tmp_input_topics.begin(),tmp_input_topics.end());
std::vector<string>::iterator last = std::unique(tmp_input_topics.begin(), tmp_input_topics.end());
tmp_input_topics.erase(last, tmp_input_topics.end());
// Do not re-subscribe if the topics are the same
if( (tmp_input_topics.size() != input_topics.size()) || !equal(tmp_input_topics.begin(),tmp_input_topics.end(),input_topics.begin()))
    // Unsubscribe from previous topics
    for(int i=0; i<scan_subscribers.size(); ++i)
        scan_subscribers[i].shutdown();
    input_topics = tmp_input_topics;
    if(input_topics.size() > 0)
        scan_subscribers.resize(input_topics.size());
        clouds_modified.resize(input_topics.size());
        clouds.resize(input_topics.size());
        ROS_INFO("Subscribing to topics\t%ld", scan_subscribers.size());
        for(int i=0; i<input_topics.size(); ++i)
            scan_subscribers[i] = node_.subscribe<sensor_msgs::LaserScan> (input_topics[i].c_str(), 1, boost::bind(&LaserscanMerger::scanCallback,this, _1, input_topics[i]));
            clouds_modified[i] = false;
            cout << input_topics[i] << " ";
        success = true;
    else
        ROS_INFO("Not subscribed to any topic.");
return success;}
So, basically, I only changed the return type from void to bool and created a local variable (called "success") to determine if any topic was found. Then I added a while loop on the LaserscanMerger class constructor to retry every X seconds:
ros::Rate loop_rate(0.5); //-- 0.5 [Hz] -> 2.0 [s]
while( !this->laserscan_topic_parser() )
    ROS_DEBUG("LaserscanMerger: Retrying to detect the topics to subscribe to...");
    loop_rate.sleep();
Hope this helps someone =).
