I am using Ubuntu 14.04, ROS jade and GAZEBO 5.0 I followed step by step the tutorial of ROS Control in GAZEBO, http://gazebosim.org/tutorials?tut=ros_control&cat=connect_ros. when I execute the command line "roslaunch rrbot_control rrbot_control.launch" nothing happens and I am not able to control the rrbot robot. Also I see this warning: Controller spawner couldn't find the expected controller_manager ros interface. I am sure that I added the plugin libgazebo_ros_control.so as they said in the tutorial. Any help would be greatly appriciated. Thanks
Originally posted by bahom on ROS Answers with karma: 36 on 2016-01-25
Comment by F.Brosseau on 2016-01-26:
I think there is a problem with Jade and ros_control with Gazebo if you install it from packages (see this link : http://gazebosim.org/tutorials?tut=ros_installing). I use ros indigo with gazebo6.
Comment by bahom on 2016-01-26:
Thanks for your feedback. You're right the package gazebo_ros_control hasn't been released yet. But how can I proceed now??
You can install ros indigo (that's what I did when I found there was no gazebo_ros_control released for ros Jade)
Comment by bahom on 2016-06-14:
Thanks for your suggestion @Brosseau
Thanks so much for your help. Finally I turned it out by building this package (gazebo_ros_control) from source
Originally posted by bahom with karma: 36 on 2016-01-26
