Hi all, I'm new to ROS. I'm using ROS INDIGO and kinect for my project.I want to create a map from the laser scan data without having odometry data .I converted the depth image to laser scan data.Then how can I create a map using Gmapping for the hand held kinect using this laser scan data?
edited question. i used hectorslam and there is some problem with tf. using rosrun tf view_frames i got image description and this is my laaunch file for depthimage_to_laserscan kinect.launch
<launch>
<node name="depthimage_to_laserscan" pkg="depthimage_to_laserscan" type="depthimage_to_laserscan">
<remap from="image" to="/camera/depth_registered/image_raw"/>
</node>
</launch>
Originally posted by David John on ROS Answers with karma: 19 on 2016-01-23
Trying looking into hector_mapping. It will build you a map from laser scans and doesn't require odometry data.
Originally posted by jseal with karma: 258 on 2016-01-23
Comment by David John on 2016-01-24:
thank you sir...it worked for me.Is there any other method using gmapping to do the same.?I read that there is another method using gmapping with laser_scan_matcher. I tried to install it but i was not able to do that.Could you please help me to install this package?
Comment by jseal on 2016-01-24:
I'm not sure. If you couldn't get laser_scan_matcher to install I would try asking a question with the problem.
Comment by David John on 2016-02-03:
Hi sir,i am able to get a 2d map with hectorslam using turtlebot package.But now when i am doing it with real kinect I'am getting an error` "[ WARN] [1453709644.419967908]: No transform between frames /map and scanmatcher_frame available after 20.001889 seconds of waiting."'sir please help.
Comment by jseal on 2016-02-03:
Sounds like your missing a transform in your tf data. Check the required transforms for the nodes your running. You can look at a pdf of your tf tree with: rosrun tf view_frames
Comment by David John on 2016-02-05:
edited previous question
Comment by spmaniato on 2016-02-14:
Check this out David: http://answers.ros.org/question/208584/hector-slam-does-not-work
Comment by David John on 2016-02-15:
did it like this,but still getting the same error.
You can either use hector_mapping, as jseal suggested, or a combination of laser_scan_matcher and slam_gmapping (or even slam_karto). You'll first need to install it:
sudo apt-get install ros-indigo-scan-tools
Then, here's an excerpt of how you'd run it from a launch file in order to "fake" odometry:
<node pkg="laser_scan_matcher" type="laser_scan_matcher_node"
  name="laser_scan_matcher_node" output="screen">
  <param name="fixed_frame" value="odom"/>
  <param name="use_imu" value="false" type="bool"/>
  <param name="use_odom" value="false" type="bool"/>
  <param name="max_iterations" value="10"/>
</node>
did like this also...but there is nothing uder the topic /map.
Comment by spmaniato on 2016-02-15:
Did you launch slam_gmapping in addition to the laser_scan_matcher and a transform between your base_link and your laser?
i lauched slam_gmapping and laser_scan_matcher.........but i didn't do that transform part.could you please help me to do that part.
You need a transform between the base_link frame and your laser frame (camera_link in your case). Assuming the camera is fixed to the base, you'd add something like:
<node pkg="tf" type="static_transform_publisher" name="base_to_laser"
  args="0 0 0 0 0 0 1 /base_link /camera_link 50" />
