Hi,
I have an Ackermann-steering style robot whose tri-phase motor encoder I read. I would like to use this information as odometry with an robot_localization EKF node. The EKF fuses IMU yaw successfully already.
I build an PoseWithCovarianceStamped (which is expected by the EKF node) in my custom node. But I'm confused about how I should integrate my position, since the encoder tells only distance driven in base_link / X-direction (forward). I tried two approaches:
  1. On every encoder tick, add a certain length vector oriented like the IMU orientation quaternion axis. The message header's frame_id is odom.
  2. On each encoder tick, add a certain length along the X-axis. The message header's frame_id is base_link.
Also, I'm not sure how to configure the pose0 in the EKF. In the first case, I tried:
<param name="pose0_relative" value="true"/>
<rosparam param="pose0_config">
  [true, true,  false,  # x, y, z, - we want x and y
  false, false, false,  # roll, pitch, yaw,
  false, false, false,  # vx, vy, vz,
  false, false, false,  # vroll, vpitch, vyaw,
  false, false, false]  # ax, ay, az
</rosparam>
And in the second case:
<param name="pose0_differential" value="true"/>
  [true, false, false,  # x, y, z, - we want x from motor encoder
</rosparam>
The first case doesn't work at all (nothing moves in rviz). The second case works really well -- In the direction the car faces when the odometry stack is launched; but not at all perpendicular to that.
How can I use my encoder information with the EKF?
Cheers
Laurenz
Originally posted by lalten on ROS Answers with karma: 102 on 2016-01-19
If you look at Coordinate Frames and Transforming Sensor Data you'll notice that pose data is interpreted relative to the world frame, while twist data is interpreted relative to the base_link frame.
One proper way of providing the data would thus be to compute the velocity from the encoder ticks and time between encoder reads and then provide a nav_msgs/Odometry message with the correct velocity set in the twist/twist/linear/x field. This can then be fed into robot_localization (the correct field has to be set to "true" for the config of course).
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2016-01-20
Comment by lalten on 2016-01-20:
Thanks a lot, that solved it!
