Hi all, I am using ros indigo.I want to convert point cloud to laser scan data.I used freenect to collect kinect data( using kinect Xbox 360).Now I want to convert this data to lasercan data to construct 2D map.I read that we can use depthimage_to_laserscan package.I used the command rosrun depthimage_to_laserscan depthimage_to_laserscan image:=/camera/depth/image_raw,but it is not showing anything.I am new to ROS and someone please help.
Originally posted by David John on ROS Answers with karma: 19 on 2016-01-19
Comment by David John on 2016-02-15:
thank you......i solved that problem
Comment by kaygudo on 2016-04-10:
hey David can you plz tell me how did you solved the problem?
Have you confirmed if the depth image is generating correctly or not? Try this to view the depth image rosrun image_view image_view image:=/camera/depth/image_raw
Originally posted by HassanNadeem with karma: 71 on 2016-02-15
