Looking through all the answers, I see one solution is to use Nodelets to share data easily, but thinking about a more general solution I can see a number of ways of doing it, so I'm wondering if any of these exist and/or are advisable:
- Pretend the CUDA memory pointer is just a value and cast it at either end.
This falls over if the message gets published to a different device, although I could add something like a Publisher device ID to detect this, for instance.
- (or 1.5) Limit message propagation to the same device.
Can ROS actually do this?
- Write a smart Publish/Subscribe routine that will transparently copy the
GpuMat
to a standardMat
if it detects the target is a different device.
Has someone tried this? It seems like the best solution, but quite a lot of effort.
- Some other technique I am not aware of
Any hints towards the best course of action are most welcome.
Originally posted by KenYN on ROS Answers with karma: 541 on 2016-01-18
